Staggered or the same all around?
Whats up guys, ive been having a hard time deciding what to go with, wanted to hear some opinions on the matter to maybe help me decide lol, im getting XD9's, either i was going to get 10x18 +18 all around, or go with a staggered look, 18x9 +20 (front) 18x10 +18 (rear). I have seen both these setups before but still cant decide what to go with, what do you guys personally think looks better, staggered or not? Any pros and cons?
Janagan_ua7 (02-11-2015)
I know it's mostly for looks but aren't staggered setups usually more functional on RWD cars? I know a lot of people like staggered but I just think it's ironic that they put it on a FWD drive
I'd stick to same personally but to each their own
The following 2 users liked this post by thoiboi:
Janagan_ua7 (02-11-2015),
justnspace (02-11-2015)
but of course, we dont know your goals or aspirations @janagan.
if you strive for a certain look, where only the staggered set up can achieve, obviously go for it.
This is why I always ask; what are you goals for the car?
if stancing out is your thing, go fourth and make the cambergang proud
I was leaning towards square all around, i was going to run the same size tires for front and rear, either 215/40/18 or 225/40/18.
The goals for my car is to be stanced out but its also my daily, i need to be able to drive the car from point A to B, by running 18x10 in the front im nervous about how bad its going to be rubbing
Received 6,470 Likes
Go 22's in the front and 26's in the back!
The following 2 users liked this post by Steven Bell:
2012wagon (03-02-2015),
Janagan_ua7 (02-12-2015)
Stay Out Of the Left Lane
Received 1,236 Likes
Also keep in mind with a staggered set up, you will have limited tire rotation options, unless of course you don't mind having the wider rim/tire on the front axle half the time
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
Lot of people, do the same tire all around, BUT more aggressive rear offset
That way, front and rear look flushed, and you are running same rubber
my original plan was to go staggered but now rotating tires will be less of an option, thanks for letting me know that, BUT what if I go with none directional tires and just swap left to right, right to left to even the tire wear. Could that help the longevity of the tire?
It will help, but remember its a FWD car. So you are still going to see much more wear on the front and be replacing them much sooner than the rears.
nuldabz
09-03-2015 05:49 PM
ptballer
09-16-2006 01:16 PM
