Springs Vrs Coilover set
GTown
I want to drop my 05 TL 5at sitting on some 18's at this momment but will be upgrading to some 19's here soon.
Questions is I want to drop the car, and what are the pro's and con's between lowering springs and coilover sets?
The difference is the price, but im sure the guru's will step in. I have my TL dropped on springs with tokico blues. And the car rides like a dream. Coilovers are fully adjustable. You dont have to take them off to raise or lower your car. As far as ride quality im sure it depends on if the coilovers have any damping controls. As far as springs there are different struts and shocks that have damping controls or are made for lowering springs. Lastly it depends on your budget too. Remember you get what you pay for. That doesnt have to be a bad thing.
GTown
BANNED
here, i found this thread located about 5 threads below yours in this section. SEARCH IS YOUR FRIEND!
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/whats-difference-between-lowering-springs-coilovers-811029/
spring are pointless ur better off spending double the moneyon coilovers because one u get spring u cantr lower it or adjust it in anyway but u get a good set of Tein coilovers like i got and u get everything damper control stiffness height everythin and the Tein Flex's are very comfortable with the EDFC
GTown
GTown
https://acurazine.com/forums/showthread.php?t=811029
Coilovers offer TONS more height/damping adjustment (If you prefer a firmer ride.. coils will do the job)
springs give ~1-1.5" drop.. comfort wise pretty much stays the same, but like lilcow said, once u install it u WONT be able to adjust height afterwards
I've had experiences with both... if I had to do it a 3rd time around, I would go straight to coils
The TL comes stock with "coilovers". All else being equal there's no performance advantage of aftermarket coilovers vs springs and shocks. The number one advantage of coilovers is to be able to adjust your height. That's important to some, not important to others. I did my research on my spring and shock combo and I've never once wanted to adjust the height.
On the flip side, I'm in it 95% for the performance and 5% for the looks. I tend to change spring rates trying to find the right balance. Since I've changed the rear spring rate a few times, springs make much more sense for me. I also have Koni adjustable shocks which will accept any spring rate out there and they offer ride height adjustment. This combo is admittedly as much as a coilover setup but again, it fits my needs better.
The one advantage that some coilovers have is that you don't lose suspension travel as the car is lowered and obviously they come with a new shock. This is a big advantage if you care about performance and even comfort to a smaller degree. The TL already has very limited suspension travel and setting it closer to the already close bumpstops will give it nasty handling characteristics at the limit and kill ride quality. I modified my Konis to retain full suspension travel which is not that hard but it's probably not for the beginner. Not every coilover has this feature and if I remember right, most don't have it.
I have HR race which did 2" front 1.75" rear with tokico blue struts and shocks. I had 19"s but sold them already. The first week i had them i had a guy offer me money for them so i sold them. and im gonna get me another set soon. And its not pointless to me. It actually rides really good. I dont have the need for adjusting, raising or lowering my car so coilovers for me.... why i dont need adjustment. And besides like i said depends also on what you want to spend. A good spring set up will do the job if thats what you want.
jmoney2001
08-12-2019 06:23 PM
1fatcrxnem1
22
06-01-2018 01:23 AM
nanos
11-12-2015 08:41 PM
braveheart
09-07-2015 08:12 AM
