Spring Compressor Recommendations
I'm looking to pick up a shock spring compressor for some work I have planned in a couple of months. I realize I could rent/borrow one from Autozone or Advanced Auto, but the prices seem really reasonable on these tools. Having never used one, which spring compressor do you guys recommend. Looking for a safe tool that is easy to use, at a good value.
Used many different types of spring compressors and even the inexpensive units work well, but make certain you get one that clamps around the coils, similar to:
http://www.alltradetools.com/catalog...ompressor.html
With this you're guaranteed that the spring won't come out and you'll not need the services of a dentist and the cost is somewhere around $35. Just tighten around coils and compress using a ratchet, or better yet an air compressor.
lastig21 (08-10-2012)
^^these are the same ones as the one you would rent at autozone. i used them several times and they get the job done. just with any spring compressor you just have to be really cautious of what your doing or else it can be really lethal.
lastig21 (08-11-2012)
^^That's the same one I have too. You have jack with the channels to get between the coils but they do the job. I've used it to remove my OEM top hats and install H&R coilovers. There no where as easy as the wall mounted pro type.
I will say you do need an air impact or electric impact to rotate the screw. No way I would even think to do that by hand.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
