spacers?
spacers?
hi guys... whats the difference between hubcentric spacers and hubcentric rings?also with just the regular spacers?does this need to be changed yearly or any particular time?and will changing the wheel studs void any warranty of the car? thanks guys
Originally Posted by MICHAELBPR
spacers and rings are different things. When you put a spacer on your car is going to push the wheel to the outside, the the hubcentric ring is to clear the gap between the center bore of the wheel and the hub. If you are planing of using spacers I'll recommend using hubcentric ones. If you have aftermarket wheels most likely you will need hubcentric rings if the weren't included. Hope this helps.
The spacers don't need to be changed. The warranty can be affected if something happens that is related or caused by having different studs. Witch means that if your Navi or radio fail you'll be ok because it has nothing to do with the studs. Hope this helps.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
rockvilleTL
Sep 19, 2015 04:44 PM
