Spacer/Bore help please!!
Old Feb 16, 2008 | 11:37 AM
Mai_CL-S's Avatar
I'm looking to get some spacers to get my rims to be a little more flush to my fenders. I have read alot of pros and cons about spacers and I just decided to just try them for myself. I was debating on 5mm or 15mm but I don't think 5mm will make much of a difference for me. My question is for the bore size do I choose the 64.1 that the stock runs shown on this site?
http://www.driftingperformance.com/p...8a878554814032
There are a hand full of bore sizes to choose from and I don't know which one to get. Please help with suggestions (besides the obvious, Buy rims that fit. I just can't get away from these because they are my all time favorite and they are discontinued) Thanks Fella's!
Old Feb 16, 2008 | 12:40 PM
Jesstzn's Avatar
To me of bore = the inside diameter I'd get it to match the hubcentric protrusion on the hub so it eliminates that issue.
By the looks of it they are hubcentric and should match aftermarket wheels.
$99 is pretty pricy .. is that for 2?
Look at this e-bay link .. same vendor ...
Spacers
Old Feb 16, 2008 | 03:12 PM
Mai_CL-S's Avatar
I think its for a pair. Thanks for the Help Jesstzn
Old Feb 16, 2008 | 11:03 PM
MICHAELBPR's Avatar
BORICUA
You need to know what is the offset of the wheels. If is 40+ and you get a 15mm spacers you will make the offset 25+ wich is too much. It will stick out the fender. If you get the 64.1 you can use the same hubcentric rings you're using now.
Old Feb 17, 2008 | 09:26 PM
Mai_CL-S's Avatar
Its a +50 off set. So a 15mm spacer would be perfect!
Old Feb 18, 2008 | 01:01 AM
BLACKURA_NY's Avatar
I have car ADD
how wide is the wheel?
if your stuck debating 5 or 15.. go ten.. those wheels look like they're sticking in the fender ALOT.... so you should have room to widen
Old Feb 18, 2008 | 09:20 PM
Mai_CL-S's Avatar
19x8. I think 15mm would be perfect. I just spoke to a local wheel shop and they said they knew a guy that did custom spacers with hubcentric rings.
Old Feb 19, 2008 | 12:44 AM
ricgrrarrow's Avatar
Stuck in Vegas.
i'm personally against spacers. due to bad vibrations, or alignment issues. but if you insist, i'd go 15 mm. and if my memory serves me right, you've got the right bore size.
Old Feb 20, 2008 | 10:38 AM
supadupahyphy's Avatar
Looking for mods in
What offset are you running right now? It seems your tires fall inside the fender, I presume you have an adjustable suspension?
