sorry, offset question again
Old Jun 17, 2003 | 12:05 AM
go-types's Avatar
hi guys, i know that putting a set of 18x7.5 rims with +42 offset will probably rub on the rear. how about if i put a +42 at the front but a +48 at the rear? also, i used to try a racing hart c2 with +42 offset at the front just to see how it look, it seems to me that it really close to the brake caliper. the reason i asked bcoz i'm looking for a set of used se37a for months (sorry, too much for me for a brand new set) & finally found one but with different offsets on front & rear. so, pls confirm. thank u for any input. btw, i will also try to read every previous offset post to see if i can get the answer.
Old Jun 17, 2003 | 12:36 AM
wiggingboy's Avatar
tell me what is the real offset on the wheels you are getting and the tires sizes.
Old Jun 17, 2003 | 01:23 AM
go-types's Avatar
not sure what u means by "real" offset but those are volk racing 18x7.5 se37a rims. 2 of the rims are +42 with 225/35/18 & 2 of them are +48 offset with 225/40/18. i'm planning to put the +42 on the front.
Old Jun 17, 2003 | 11:22 AM
benzo555's Avatar
boo
Yo should be fine if you do that. Im currently running +43 with 225-40-18 and I had to roll the fender since I have H&R sports
Old Jun 17, 2003 | 10:16 PM
SilverUA5's Avatar
why not just get all +48? is this something that's on special?
Old Jun 17, 2003 | 10:32 PM
go-types's Avatar
read the post. that's a set of used rims & i couldn't afford to get a brand new set for at least $2400 w/o tires.
Old Jun 17, 2003 | 11:45 PM
SilverUA5's Avatar
well, good luck trying to get a tire rotation........
Old Jun 19, 2003 | 09:01 AM
SlyTLS's Avatar
Bada Bing
I'm running 18x7.5 with a 42+ offset and 225/40/18 tires and I had to roll my rear fenders. I'm also dropped on coilovers to the point where there is only a 1 finger gap btw the tire and my fender. I can tell you that b/c of the offset being so low (they sit very close to the edge of the fender) that you will kick up a lot more pebbles when turning and they will hit the side of your car.
Old Jun 19, 2003 | 07:42 PM
go-types's Avatar
thanks all for the input & i have decided to not buying the set.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
mellsonnj
Sep 24, 2015 04:42 PM
