RUBBING?!? Help Please...
Old Jul 24, 2009 | 11:47 AM
Glocknerd's Avatar
Question RUBBING?!? Help Please...
I just got some 20" rims and it wasn't rubbing when I left the wheel shop but then as I have been driving around town I have noticed that when I go over a dip in the road when the suspension bottoms out (not literally) or is at its lowest point there is a slight 'krrr' sound like the tire is rubbing. It is coming from the rear wheels on both sides, but when I go look at the tires there are no marks Anyway here are the specs on the tires and any help would really be appreciated.
225/35/20 35mm offset
THANKS!
Old Jul 24, 2009 | 11:54 AM
Maddizm's Avatar
Do you have an A-Spec kit? You dropped? I suspect you're rubbing on the inner fender, but then again with a 35 offset are you tucking at all or does your wheel sit flush? How wide is the rim? Is the sound rubber/plastic or metally? Anyhow, it is probably b/c you're running a 35 series tire. If you drop down to a 30 series, that would probably help.
Old Jul 24, 2009 | 01:16 PM
Glocknerd's Avatar
Thanks for the quick reply
Here is a pic of my car and wheels... they sit pretty much flush and the width is 8.5" (forgot to put that in the first post... DOH!) It has no drop at all and is not A-Spec or Type S but I beleive it has the A-Spec kit on it (sorry I am a new TL owner) The rubbing sounds like plastic against rubber from what I can tell. I will try to get pics from an angle soon to give you a better look.
Old Jul 24, 2009 | 02:36 PM
Opel's Avatar
remove the wheels and look for "shaved" parts of the fender liner...and plastic surroundings...if tire rubs..it will leave marks on where it rubs.
35 offset will push the edge of the rim closer to the outside resulting in less clearance
Old Jul 24, 2009 | 04:16 PM
Glocknerd's Avatar
Thanks for the info... I am going to put it up on a lift tonight and we'll see what I find out.
Old Jul 24, 2009 | 07:07 PM
Maddizm's Avatar
There's also a plastic piece on the A-Spec kit that may need some sanding down. It's where the kit attaches to the rear bumper. There are some screws that hold it against the bumper. I small corner of it might need to be shaved off.
Old Jul 25, 2009 | 02:17 AM
quad150db's Avatar
Shouldn't 20 inch wheels be using a 30 series tire ?
Old Jul 25, 2009 | 02:32 AM
mamitaxchula's Avatar
Blanka
^ you can run 35 series tires on a 20 it isnt unheard of...He is probably most def rubbing on the Aspec kit where gatdammit said.
Old Jul 26, 2009 | 10:52 AM
TL on "20"'s Avatar
Here is mine they are 8.5 front 9.5 back 40 offset and a 245 35 20 tire !! they only rub on the back with 2 people on the back and only on the highway at high speed when i hit bumps
Old Jul 26, 2009 | 01:41 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
roll the rears done
Old Jul 27, 2009 | 09:50 AM
playtex's Avatar
shit dude I have 24's on mine, as of right now the car wont move but we rolling the fenders and doing some cutting today
Old Jul 27, 2009 | 09:55 AM
dtan1691's Avatar
get stiffer suspension.. like coilovers.. give the rear wheels negative camber and you'll be set man
Old Jul 27, 2009 | 11:40 AM
Maddizm's Avatar
I have 35 series right now. I still rub with the coilovers AND rolled fenders AND negative camber. It's either the plastic piece on the ASPEC or inner lining of your fender- that's where mine is rubbing. If you get 30 series tires, I don't think you'll have any rubbing after that.
Old Jul 27, 2009 | 12:20 PM
Glocknerd's Avatar
I looked at that after reading your post but I don't see any markings at all to indicate that it is rubbing there. I didn't get a chance to put it on the lift this weekend either. The wierd thing is that it only rubs when I go over a bump or a dip, so when the suspension drops it rubs for just a second. Now I did do another test this weekend when I went out drinkin' and that was to put 4 people in it. When it has 4 people it will rub when I take corners at normal speed so I have to slow down when cornering. The thing I'm confused about is I don't see any rubbing marks on the tires?? I'm just going to have to take the tire all the way off and get in the wheel well and look.
Old Jul 27, 2009 | 12:22 PM
Glocknerd's Avatar
WHEW! OK so its not just me!! WOO HOO!! haha Anyway so if it is just the inner plastic of the fender (which I think it is) then do I have to worry about it rubbing??
Old Jul 29, 2009 | 12:10 PM
Maddizm's Avatar
I guess not really, but I hate that sound... My tires are still A OK, but it sounds bad when I have people in the car.
Old Jul 31, 2009 | 09:25 PM
bzyrice's Avatar
roll your fenders.. I did that and it solved by rubbing issues.. now i can have people in my back seat and not cringe lol
Old Aug 5, 2009 | 06:14 PM
TRIOD3SIGNS's Avatar
SHAWD 04TL is in
I KNOW WHAT YOUR PROBLEM IS..... 99.99999% SURE!
I have the same setup with 20's, right now you dont notice it cuz you havn't been riddin the 20's long enough to show the wear. The rubbing is happening on the ASPEC KIT torward the back of the wheel well. NOT A BIG ISSUE AT ALL... right now I bet its rubbing some of the clear paint off of the tab that folds into the wheel well, after that, you will start to rubb off the paint and start to see the black of the plastic fromt he KIT. To fix it, just cut the top inside corner of the kit off.
The reason this hapens is because the shocks & springs are angled a bit torwards the rear, instead of straight up & down. Therefore when you hit a dip & your tire sinks into the wheel well, it also travels torwards the back. (just enough for your 20" tire to rub against that ASPEC KIT.)
So you can sleep easy tonight, when this happened to me, my main worry was about rupturing or slicing the tire with the metal part of the upper fender. Luckily it was alot less than that.
Old Aug 6, 2009 | 11:00 AM
NTICED's Avatar
Darryl
well im getting 20s on friday and am now worried i generally have 3 to 4 ppl riding in my tl is this problem only with the a spec kit
or will it rub in a non kit also
Old Aug 6, 2009 | 06:35 PM
SHAWD 04TL is in
The rubbing is not a big issue regardless.... If you dont have the aspec kit or mudflaps, you might not even rub.
Old Aug 10, 2009 | 04:18 PM
Glocknerd's Avatar
Thumbs up
GATDAMMIT YOUR GOOD!! haha It was that exactly!! At the top part of the A-SPEC Kit it was rubbing when the car reached its lowest point, Thanks for all replies!! I don't know what I would do without this site!! HAHA
Old Aug 10, 2009 | 04:30 PM
Glocknerd's Avatar
Question Cut the corner, Sand the corner, or Hammer the corner???
So I was going to just cut that corner off but then I thought well maybe it would be worse that way because its giving it a sharp edge?? Plus there is that screw right there, I just took a rubber mallet and went to town with it it moved about a half an inch and seems to be OK. You think I should cut it and ill be OK?
Old Aug 10, 2009 | 05:45 PM
DecaFe1's Avatar
youll have no problem cutting it
Old Aug 10, 2009 | 06:35 PM
Glocknerd's Avatar
SWEET!! Thanks a lot!
Old Aug 10, 2009 | 11:07 PM
Maddizm's Avatar
lol... Glad I could help... it's just what I learned from this site, AND having my own 20s... happy driving!
Old Aug 12, 2009 | 01:20 PM
spinz22's Avatar
9th Gear
By any chance do you have pictures of where you cut off???
did you have to take off the screw.
I'm in the excate situtation and this tread has answered my questions also, but would like to see excatly where i need to cut/ grind down!
Old Aug 13, 2009 | 12:16 AM
TL on "20"'s Avatar
mine does the same thing and is rubbing with the screw of the rear aspec lip but my rim is 9.5 !! jeje
Old Aug 13, 2009 | 12:31 AM
goturcode's Avatar
03 ACURA TL TYPE S
sorry to go off topic but does anyone know how 20s would sit on a 2g tl
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Tribalheads
Sep 29, 2015 03:24 PM
