RJ Legends -- rust?
Old Apr 2, 2009 | 09:09 PM
jmkiang's Avatar
zaino'd
RJ Legends -- rust?
I'm getting A LOT of rust building up inside the little holes circled above.
I've cleaned them out with a chopstick, MF towel and some spray wax but it keeps coming back! If water gets in there (wash, rain etc), rust-colored water will drain out from the holes and get all over my wheel.
Its not permanent but for a ~$350 wheel, I wouldn't expect this.
Anyone else experience this?? If you want, I can provide a picture of my wheel "bleeding".
Also, is there anyway to fix this?
Maybe apply a layer of clear inside the hole with a small brush?
Old Apr 2, 2009 | 09:23 PM
rondog's Avatar
Former Sponsor
plug the holes from behind with a dab of silicone or any other waterproof material, those holes are there for alignment purposes, its a simple fix, no biggie.
Old Apr 2, 2009 | 10:07 PM
jmkiang's Avatar
zaino'd
^ Thats it? It seems like the rust doesn't only come from the back of the hole though...
Old Apr 3, 2009 | 03:36 PM
dragonlord's Avatar
I had the exact same problem. I just kept them very clean, I couldn't figure it out either.
Old Apr 3, 2009 | 03:40 PM
jmkiang's Avatar
zaino'd
^ Yo come to the meet! 4/19 and 4/25... pick your poison
Old Apr 3, 2009 | 05:10 PM
djbonsu's Avatar
"Like None Other"
Oh Geez....sumtin i dont wanna hear
Old Apr 3, 2009 | 06:11 PM
jmkiang's Avatar
zaino'd
Yeah man seriously...
It definitely is a big deal...
Old Apr 3, 2009 | 06:27 PM
Timeless's Avatar
The wheels won't rust...they're made of aluminum. Aluminum doesn't rust. Plug the holes on the rotor side and you'll be good to go.
Old Apr 4, 2009 | 05:17 AM
dragonlord's Avatar
You will still get the rust from the front side. By plugging the hole, the water stays in until you drive away.
Old Apr 4, 2009 | 07:13 AM
CGTSX2004's Avatar
The rust is not from the wheels. The rust is from the rusting of the exposed rotor surface. As the pads wipe this off the surface, some of the rust will lodge in the little holes. Just keep it clean and everything will be fine.
Old Apr 4, 2009 | 08:39 AM
Jesstzn's Avatar
I didn't have the RJs but another brand with the same holes. I'll bet if you remove the wheel and look at the back side where the hole is there is a cuped area that is collecting water and exposing it to the rotor face. The rotor face rusts and the brown water runs out.
Do like said above .. remove the wheel and squeeze enough silicone sealant in the hole from the back side to plug it. You will get no more rusty water.
As for this poster .. Aluminum doesn't rust brown .. the water that accumulates in the tiny holes ( that BTW are also finished with the wheel finish ) will just be clear water.
Old Apr 4, 2009 | 11:28 AM
jmkiang's Avatar
zaino'd
Good to know.
Old Apr 4, 2009 | 11:43 AM
ballinfizzle89's Avatar
FizzyStatus!
Yessir, kinda late for this but my Work VS-XX's used to do the same thing
Old Apr 4, 2009 | 09:34 PM
rondog's Avatar
Former Sponsor
Thats just the rotor rust coming thu after rain or a wash, the aluminum from the wheels doesn't rust. In all honesty, its not a big deal, plain old hole plugs will work, I never experienced this, but I've heard about it from our servo wheel which also has those holes.
Old Apr 4, 2009 | 09:52 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
i'd be more worried bout the curb rash
Old Apr 4, 2009 | 10:23 PM
sherwin991's Avatar
04 Abyss Nav, 07 KBP TL-S
jmkiang, here's what I did, cured the problem 100%
- Remove the wheels (do this to all 4) and use a brass or wire brush to knock the heavy rust off the rotor hat.
- Spray each rotor hat with that rust converter primer stuff. It comes in a spray can and can be bought at Advance Auto Parts or most any auto supply store. It'll turn the rust into black primer. Let it dry, then repeat once more, then let that dry completely.
- Brush any loose rust flakes off the hub mounting surface on the rim, then, using Permatex nickel based anti-seize compound, apply a small amount of anti-seize to both the rotor hat and the back of the wheel where the wheel hub meets the rotor.
- Mount the wheels and worry no more about rust.
I did this when I first bought my Legends last year, and still no issues. Hope that helps you.
Old Apr 5, 2009 | 10:16 AM
Fulani has a TL's Avatar
hahahahaha
Old Apr 5, 2009 | 11:58 AM
jmkiang's Avatar
zaino'd
Yeah that wasn't me.
sherwin, thanks for the tip!
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
lanechanger
Oct 13, 2015 10:56 AM
polish_pat
Sep 30, 2015 12:22 PM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
