Rims and Tires arrived today!!!
A'ight ladies and gents. Had 2 delivery guys bumping into each other today. One for my tires (235/35/zr19 fronts, 245/35/zr19 rears) and the other for my rims (19x8.5ET38 fronts, 19x9.5ET38 rears). I've searched quite a bit on how to transfer my oem tire pressure sensors to my new wheels but nothing really quite clear and definite on how to go about doing that and what "reseal kits" and part numbers are needed to do this. Along side that same line I need new set of lugs so recommendations and help is much needed. I'm a bit too anxious I think cause i'm even thinking of taking off tomorow so I can stare at my new sex rims with my new rims I know I could have bought new tire sensors but the salesman who sold me the rims was thinking he would save me some money and recommended that I just remove my oem sensors and switch them to the new rims/tires. Problem now is I have no idea what parts I need for that. Please help asap so I can roll on these new set this weekend Thanks in advance for any help.
They can usually be transferred over without new parts. The installer needs to be careful when removing the tire as not to do any damage to the sensor, but the TPMS has been out long enough now that most shops would know how to properly remove the tire.
If there is a problem, I believe Acura has a replacement valve that includes the seal for around $9 each and the sensors are only @ $35 each discount.
Aftermarket has kits for @ $4.00 per wheel that incudes the valve core and cap as well as the grommet and nut.
Also what would you folks recommend the finish I should get for the lug nutz for these wheels http://www.vertiniwheels.com/ should it be black or chrome finish? I'm thinking black I would like some input which would look best. And please tell me where you folks got your lug nutz at and which one you got so i have an idea.
Where did everyone get their wheel lock lug nutz for their new rims!? I can't decide whether I should get chrome finish lugs or black for my rims. Dang. Tomorow I will go and hunt down a installer that will be able to transfer my tpms and balance and mount my whip's new shoes!!! But I still have to try and see if the stock lugs will fit the new rimz is that what everyone is doing?
If new, they should have come with lug nuts, if not make certain you purchase the correct design to fit not only the stud M12x1.5, but also the design/shape that fit the wheels. Factory is a ball design while most aftermarket are conical and they can't be switched, so make certain you check the fitment on the wheel.
Bolt pattern (in): 5x4.5
bolt pattern (mm): 5x114.3
Offset range (mm): 35 to 45
Wheel size range (in): 17x8.0 to 20x9.0
Front center bore (mm): 64.1
Rear center bore (mm) 64.1
Stud size: 12x1.5
nuldabz
09-03-2015 05:49 PM
