Rim Question
from my knowledge, if you're getting 8" width, you should aim for no less than +48-49 offset, +50 and higher is ideal though. +45 offset would be fine with a 7.5" width though. rubber i would say for a 8" width you would need 235-40-18, 225-40-18 for 7.5"... somebody correct me if i'm wrong.
my 18x7.5 ....offsets 48....and i rub with 3 people in the back...occasionally with 2 people....this isa fter i cut the tab....but my tires are also 225/45/18 so3s....thats size is bigger then stock..and the so3 are wider then most tires..because they come out past the rim...thick sidewall...
Originally posted by Mr
What about 17x8.5 with a 45 offset... Will I get rubbing....
I know 50 or higher would be better but I can get a deal....
