Request for offset advice
Old Sep 27, 2011 | 01:28 PM
dm6ci4's Avatar
allergic to wintertime
Today is my best day for a while to deal with buying new wheels, and I have a question. I am considering two wheels:
1. 19X8.5, 35 offset, about 300 each, want to do 245/35 tires
2. 19X9, 38 offset, about 200 each, want to do 245/35 tires
I am pretty sure the 8.5 +35 will fit, but I prefer both the design and price of the 9 +38. Will the 9 +38 with 245 tires fit an 06 automatic base front and rear? I am not lowered and don't plan to be.
Old Sep 27, 2011 | 01:42 PM
Herblenny's Avatar
In theory, not much of a difference between the two wheels as 9s will stick out 3mm but the tires will be little bit stretched vs 8.5 width with same tires.
Just remember that tire is what's going to rub the car and not the wheel.. So, even though width and offset is important, tire choices will also make a difference.
I have tried Michelin PS2s and also Advan Sports and Advans sit bit wider than PS2.
Old Sep 27, 2011 | 05:06 PM
dm6ci4's Avatar
True. I guess if it is likely to be that close, maybe I should look at a less aggressive offset. The 8.5's also come in a 40 offset, but if I want to go less aggressive with the others, I'm stuck with an 8 width, 38 offset.
Old Sep 27, 2011 | 09:02 PM
Herblenny's Avatar
Hmm.. 5mm isn't much. May I ask which rims you are looking at?
Old Oct 1, 2011 | 12:01 PM
dm6ci4's Avatar
The ones I was really interested in were Luxe Lx10, but I have been told by so many people they won't fit that I have decided to go in a different direction. I appreciate the responses.
Old Oct 1, 2011 | 05:45 PM
rep57's Avatar
Dm6, you shouldn't have any issues. I'm running 19x8.5, with 38 offset, lowered about 1.5", no fender roll and I have no issues.
Old Oct 2, 2011 | 09:24 AM
dm6ci4's Avatar
Thanks.
Old Oct 2, 2011 | 09:45 AM
wtf8269's Avatar
I think you guys are missing the part where he said he's not planning on lowering his car. You shouldn't have any real issues with either of those. Only after a drop do things really become a concern.
neuronbob
23
Jul 16, 2019 10:48 AM
soupi
14
Nov 15, 2015 11:15 AM
IIDXholic
3G RLX (2013+)
23
Oct 19, 2015 09:40 PM
Timmy18
Oct 17, 2015 03:58 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
