rear miss-alligned: camber kit?
SO I have my rear tires that are shot with the inside chewed pretty bad.
The Goodyear dude suggests a camber kit to fix that as he says the Acura specs don't have room for adjustments?
How true is that?
How true is that?
2007 TL
1 Post
Your camber is stock at 1 degree so if you dont rotate them or flip them they will wear out fast.
There is no camber adjustment in the front or rear for a tsx or tl. Gotta get aftermarket. You can still adjust the toe which normally wears out tires faster than camber.
well..i usually have asymmetric tires, so no much rotation u can do. Yes he was suggesting after market camber kit. So you cay camber isn't that bad on tire wear.
edit: plus I have no plan on dropping my car in the future.
Yeah, I'd have to say the toe is out of whack. Had the same thing happen to me on my TL. Inside 1/4 of tread was prematurely worn to wear indicators. Had it aligned when I got the new set of tires, haven't had a problem since.
09-04-2015 08:03 AM
nuldabz
09-03-2015 05:49 PM
