Rays Duralock Wheels Lugs
I have a 07 tl-s, and i bought some rays lug nuts to put on my rim.....was it a bad idea to put it on the tls gunmetal rims?
You are going to damage your wheels or worse by using aftermarket lugs on your stock wheels. Take them off before you injure yourself or someone else.
CGTSX2004 has spoken the truth!
From Tirerack.com: http://www.tirerack.com/wheels/tech/...jsp?techid=102
While many aftermarket alloy wheels are designed to use your car's original lug nuts or bolts, others require new hardware. It may be something as critical as differences in the wheel's lug seat design as shown below, or something as simple as shorter lug heads to allow the wheel's center caps to fit. If your new wheels require new hardware, your invoice will list the appropriate quantity identified by our part description, beginning with an "N" for lug nuts or a "B" for lug bolts followed by the size, pitch, seat design, length and the appropriate lug wrench socket size.
NOTE: Keep a set of your vehicle’s Original Equipment lug nuts or bolts in the trunk just in case you ever need to use your factory spare tire, which must always be installed with the Original Equipment lug hardware.
Tuner and Acorn lug nuts are the same thing. Don't know about newer Acuras, but if the OEM nut is tapered at the end then it's Acorn/Tuner. Older Hondas and maybe Acuras as well used Ball style lug nuts on OEM wheels.\
-stickwidit-, if you can get a pic of the OEM lug nut I can confirm.
^That would mean it's a ball seat.
http://www.gorilla-auto.com/lug.nuts
Acorn=tuner=tapered 60 degree angle.
Proceed to page 7, third row. Honda Lug, ball seat. Like I said before I know older hondas used the ball seat OEM, but wasn't sure of newer cars.
nanos
11-12-2015 08:41 PM
