Question on Volk wheels
Now with i-Vtec
Originally Posted by importspeed24v
You will need the Rays lugs. They are thinner than the typicaly lug...
You do not have to use Ray's Engineering lugs. There are several other brands that will work just fine.
StockTL- Try the McGaurd Splinedrives as they will work just fine for you.
you don't have to use Ray's lug nut, there's other ones that you can use that will fit... But if you're going to buy Volks rims why not do it right and get the Ray's lug nut too? if you're going to buy the Ray lug nut go with the extended lug nut, I think they're better...
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
300whp 237wtrq
not true either on the race type lugs. you don't need "RACE" lugs, but he's right you cannot use stock lugs.
I'm using Gorilla lugs and lock nuts on my volks. the lug nuts besides the lock nut is pretty generic.
I believe it needs to have a certain type of "head" they have rounded and ones that look like / \...
Now with i-Vtec
Yeah it's called an "Acorn" style or "Tuner" style (which usually refers to the skinnier lug nuts with an Acorn head/seat)
Any lug nuts will do as long as it has tapered seat and fits inside the stud holes of the wheels.
The OEM wheels have ball seats. The OEM lugnuts fit (at least on my GT-V), but they won't seat properly.
I have regular 6 sided 19 mm lug nuts with tapered seat on my GT-V and they fit just fine.
You generally do NOT need Acorn or Tuner style lugnuts on VR wheels.
Why don't you test fit your stock lug nuts first with your VR wheels. If they fit in the hole, any regular 6 sided 19 mm tapered seat lug nuts will fit.
Will do that, thanks!!!
tehLEGOman
Received 1,982 Likes
Which style rim do you have your eyes on?
.:HALCÓN DE LA NOCHE:.
DiamondJoeQuimby
09-10-2015 11:40 AM
