Props to Tire Warehouse
Dr. Feelgood
Yeah baby. Well I went to another Tire Warehouse branch on Grafton St in Worcester today to get a printout to show Acura that the rims were bent. One of the techs, Dan, thought it was odd that I got 2 bent rims and decided to rebalance the tires and rim. It turns out that the 2 rims weren't bent after all.
The fix-a-flat I pumped into one of the tires threw the Hunter Roadforce off. They took off the tire and emptied it out. Problem solved!
The 2nd tire threw off the balancer as well because Townfare Tire (originally mounted them) didn't mount the tire right. He had to adjust it and guess what? Problem solved!
The car feels awsome now and no more shaky wheel. I'm happy again!
Oh, also pumped nitrogen which is guaranteed to keep the tires at the same psi pretty much forever.
Thanks for listening.
2016 E350 Sport
acura-cl.com OG
BTW, what is the nitrogen supposed to do?
I have heard it is supposed to help with gas consumption, but nitrogen is actually thinner than oxygen and would really piss out of any leak/hole in a tire. i wonder how the TPMS sensors would react to nitrogen.
Registered but harmless
Received 1,106 Likes
Nitrogen atoms are larger than oxygen atoms; the theory is that nitrogen will not migrate through the tire material itself as easily as oxygen (from air) in the absence of a leak. I have heard that Costco uses nitrogen for its tire installs, but have not verified that.
Dr. Feelgood
In regards to nitrogen, I was told that when you use air in the heat, it cause condensation inside the tire causing the inside of the rim to rust. With nitrogen, supposedly the pressure does not change in the hot or cold climate and will not cause the rims to rust. And best of all, I get free nitrogen fill ups.
Dr. Feelgood
Originally Posted by Excelerate
Isn't it great to find an easy fix to a problem like that?
CostcoFanAUS
09-18-2015 06:05 AM
