Project Kics Neo Chrono Lugs
Nikon Neck Beard Krew
I saw a set of these "NeoChrono" lugs on a car with black wheels this weekend at a car show. The owner wasnt around so i couldnt get any details about them. After searching for the last hour or so ive come across these Project Kics lug set.
Now i have a couple questions about these.
1. These are the only ones i could find...there has to be other companies that make similar styles.
2. What are other names for this style of finish.
3. What size do i need for a 04 TL Auto? Ive read they fit acuras, but just want to make sure.
Here are some pics for reference.
![](http://i12.photobucket.com/albums/a226/rustyspikes/racinglab_1956_284672921.jpg)
![](http://i12.photobucket.com/albums/a226/rustyspikes/import-store_1957_2475188826.gif)
![](http://i12.photobucket.com/albums/a226/rustyspikes/racinglab_1956_284744699.jpg)
Thanks in advance for any help.
OMGWTF4THGENTL
http://www.honda-tech.com/zerothread?id=1358129
Project Kics is the only kind I've seen like this... It's just a zinc type coating... I love the advertising "titanium like finish"... I'd shy away from any knockoffs of questionable quality.
All Honda's use the same lugs (Actually almost all inports use the same lug size)... Can't remember the size something like 1.5. Nissans are the onyl ones who use a finer thread at 1.25. If it'll fit a Honda, it'll fit the TL.
A bit WAY over the top for me...
You do realize those are "race lugs", as in they're an open ended to save weight, but are not designed for daily driving use... Open ended lugs will allow moisture to enter the space between the lugs and stud allowing corrosion to build... that's bad.
To me, these are a collosal waste of money. The weight savings is negligiable, they scream "steal me" as int hey offe rno security, and they should only be used in good weather... and they cost $200!
4 McGard Splinedrive + 1 McGard Security lock on each of my Volks.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
I saw lug nuts like that last year, but they were made out of full titanium and they retail about $600 for 20, I can't remember the brand but i'm sure if you do more research you'll be able to find it. You'll ned the 1.5mm to fit your TL
Thanks guys.
Let me correct myself, it's $599 CAD and $550 USD
http://www.aj-racing.com/catalog/pro...&cat=0&page=10
-Arsenic-
ARC makes the best looking heat treated titainum lugs. Only problem is, you wont find them unless you go to Japan to get them. The guy who owns these went on vacation to Japan and picked them up while he was there. I cant find them on the internet anywhere..
![](http://memimage.cardomain.net/member_images/2/web/458000-458999/458377_44_full.jpg)
Damn those look great.
Ive seen the ones on aj-racing, and evasive.
So i guess im narrowed down to paying 200+ and having open lugs. And i dont want the stud going beyond the lug, but dont want the extended lugs sticking 5ft off my wheels...ah the hasle of good looking parts
Thanks guys
http://www.aj-racing.com/catalog/pro...0&cat=6&page=1
neuronbob
23
07-16-2019 10:48 AM
