Please answer this question at least
Old 05-26-2002 | 11:34 AM
bigman's Avatar
'Big Daddy Diggler'
I'm sorry for the way i wrote the topic, but i can never get any help in the wheel forum and i dont want to post it anywhere else. I want to get the RH evo C5's with a 42 offset. i currently have adr kasai with a 38 offset. I do rub, but very little in the back. If i get the C5's with a 42 offset on a comptech drop, do you think i will rub with 225/40 tires. Also overall do you think the construction of the rim is better then ADR's because i already replaced an adr. The pothole i hit would have probably bent any rim though. Thanks for all the help.
Old 05-26-2002 | 07:07 PM
Shoofin's Avatar
Are you sure the off-set is that low in the C5's? My friend had them on his TL in 225/40 with Comptechs, no problems......I coulda sworn the offset was higher..
Ed
Old 05-26-2002 | 07:18 PM
WiLz's Avatar
what size are they? 18s? 19s?
Old 05-26-2002 | 07:26 PM
SimTypeS's Avatar
...and then there was One
What size of tire do you have on your ADR's?
Old 05-26-2002 | 08:11 PM
bigman's Avatar
'Big Daddy Diggler'
The size of the ADR's are 18x8 sitting on 225/40 and the size of the C5 Evos are 18x7.5 with 225/40
Old 05-26-2002 | 09:05 PM
TypeSDragon's Avatar
Loving my 08 TLS!
At least get 45 offset with a comptech drop. If not, 42offset will work, but you will need to roll the fenders.
Old 05-26-2002 | 10:28 PM
bigman's Avatar
'Big Daddy Diggler'
ok, do any of you know thw quality of rh evolution. I know they are made by another company to look like racing hart 3 piece wheels. But i bent and adr and had to buy a new one. I hit a really bad pot hole so i dont think any rim would have survived, but i want to know about the overall fit and finish of the wheel.
Old 05-27-2002 | 01:48 PM
His Offset Was A 51 Right Ed
Old 05-27-2002 | 03:11 PM
NSXNEXT's Avatar
Yeah but that's for the 3-piece RH C5, not the 1-piece RH C5 evolution.
+42 sounds about right for the 1-piece.
Old 05-27-2002 | 06:41 PM
WiLz's Avatar
thats for a 18X7.5 right?
Old 05-27-2002 | 09:44 PM
Lawaia's Avatar
Moderator Alumnus
The 18 x 7.5 RH C5 will fit without rolling the fenders. However you will need to trim the bumper tabs on the rear, something you should have already done with your ADR's.
navtool.com
3G MDX (2014-2020)
32
01-20-2016 12:43 PM
navtool.com
31
11-16-2015 09:30 PM
navtool.com
09-25-2015 06:15 PM
Eggs999bacon
09-24-2015 11:08 AM
