People with Tein S tech's PLEASEE HELPP
Hey guy's,
about 3 weeks ago, I got my Tien S tech's installed on my 04. last week or so, whenever I go over even a small bump or a shallow speedbump on the road, the car's tail seems to sway out of control. The ride is not as tight as i thought/hoped it would be after these springs. Is this normal?? Any suggestions? Hope it is something simple as incorrect air pressure in the tires...
thanks.
thanks.
Now with i-Vtec
First did you get an alignment afterwards? If not you need too because your "toe" is outta wack. Mine behaves just as it did before lowering it with the S-techs which means the rear does have a slight shimmy (doesn't sound as bad as yours though). The comptech RSB should greatly reduce this if not eliminate it completely. I will be ordering my RSB soon.
Modding my TL in
1 Post
I don't have any problems. Sure the S-Tech's are soft, but not a bad choice. This is my sixth car that I have lowered and by now I would know of issues.
BTW - did you cut the bump stops in the front/rear for the stock shocks? If not, that may be your problem.
whats the bump stops? I did'nt know that was required.
How are the springs supposed to be installed? The closer coils on top or bottom?
HTML Code:
http://www.modacar.com/Merchant2/graphics/00000002/tein_springs.jpg
BoricuaTL
04-08-2016 01:08 PM
HydrasunGQ
09-14-2015 10:14 PM
DunesCreations
09-09-2015 12:03 PM
