People with 19s... post here...
Old Feb 21, 2002 | 09:57 PM
Crzy Acura's Avatar
OK im sick of people telling me that 19s will bend easy. OK thats all fun and tru perhaps if you lived in the city, rite? How about those guys in the suburbs where the roads aren't bad....
Heres the question... Those with 19s, how many times have you bent a rim since you had them. And do you live in the city or not.
Old Feb 21, 2002 | 10:02 PM
valuetl's Avatar
I don't count because it doesn't snow in honolulu.
Old Feb 21, 2002 | 10:06 PM
is300eater's Avatar
I Shoot with a Camera
(Hehehehe), it's me.... again... and I'm going to tell you (again) how much I like my wheels... Nah, I'm just kiddin'.... you've heard enough already from me... but I just wanted to be part of this "tread." If you are in the suburbs... You'll be fine... It's like I said, you WILL get real familar with all the potholes in your area... They are the first set of 19s I've ever own... I used to drive a big Dodge truck... and I didn't care at all about bumps and holes... (sometimes, I didn't care about sidewalks too... LOL). Then again, keep in mind... mine ARE forge (=stronger). There has been times... where I hit some hole so hard, I pulled into the nearest gas station to check....
Old Feb 21, 2002 | 10:08 PM
Crzy Acura's Avatar
Well thats not a big deal by me either, since every spring the town fills in all the potholes pretty quick that was made from the winter.
Also, is300eater im sick of hearing your comments.. cuz you are nothing but a tease with that small picture in your sig!!! I wanna see more pics.. your car looks hott!!!
Old Feb 22, 2002 | 09:34 AM
ArN 2000 TL's Avatar
Moderator Alumnus
I have 18''s and bent the front right rim twice. Once I hit a HUGE pothole in Jersey going to a meet. The second time my friend borrowed my car to go to JFK and was most likely driving like a manaic. The two times they bent was because of excessive hits though.....i drive into manhattan once in a while and am careful when i am driving. I have been thinking of getting 19''s, but am worried for this reason, because it will be even less tire than i have now :wow:
Old Feb 22, 2002 | 10:08 AM
is300eater's Avatar
Sorry about NOT having much pictures... here's a page you guys can check out... my car starts on page 4, then into page 5, this was at a meet last month in Brea, Ca.....
http://public.fotki.com/stanman/1502_socal_tl_meet/
Old Feb 22, 2002 | 05:54 PM
samzilla's Avatar
i have 19's, but i live in orlando... no snow or extreme weather changes that cause the ground to crack and dip-- BUT do beware of car washes... they killed my wheel. oh, and i haven't bent a thing, but then again i'm in a smoothly paved "city" and i'm pretty careful
Old Feb 22, 2002 | 06:32 PM
Crzy Acura's Avatar
Cant go through my car wash anyways... i just went there to find out my car doesnt fit with the drop and bodykit.. its ok, i like hand washing in 30 degree weather anyways.
Old Feb 22, 2002 | 09:15 PM
NSX4dr's Avatar
Original Member #81
I have 19s.....I've only bent one wheel and I've had them for over a year.
I'm going to be on my 2nd set soon.................
HREs on the way:wow:
Old Feb 23, 2002 | 02:49 PM
2K2 TLS's Avatar
I have had my 19's for about 5 months and so far have NEVER bent a single rim. Im running 235 35 r19 on a 19x7.5inch rim w/+50 offset. Lowered on H&R OE sport.
I live in San Jose, CA and we have our share of potholes. I often drive up to SF and they are pot hole CENTRAL. Here are the main reasons I think rims get bent:
1. your tire is not wide enough to cover the rim properly. (ex. 235 35 r 19 on a 8 inch wide rim) In this case if you look at your tire from directly above you will see that your rim's edge shoots out a little further. thus giving it a greater chance of bending.
2. Your car is butterflying too much. the more it butterfly's the closer the inside lip is to the ground and thus potholes will bend your rim easier.
3. Improper tire inflation. Unlike our stock tires my 235 35 r19's require a PSI of atleast 38.
These are not all the factors but they are the ones i experienced. I had a 98 prelude before w/ 225 40 r 18 and the rim was 7.5 inches wide also. I didnt know it at the time but the tire was undersized. on a 7.5 inch rim you need atleast a 235 tire. my car was also pretty low and had a big time butterfly problem. After driving around for only 4 months i bent a rim. These are the same size potholes im running into now with my 19's on a heavier car and no problems on my tl. not to mention my 19's have a lower profile.
Old Feb 24, 2002 | 01:53 AM
is300eater's Avatar
Okay.... so what do you think about my set up? I have 19X8 with 235/35-19 tires... Do you suggest me, going up to 245/35 tires? I don't know if it'll fit...
...and another thing... what does "butterfly" mean? I kinda have an idea... someone vaguely brought it up at the meet last month... but I wasn't paying enough attention... And what can I do to prevent that from happening? I have Neuspeed springs BTW (1.75 lower front and back).
(oh *****in' with this reply... I became an "insane poster"!!!)
Old Feb 24, 2002 | 12:54 PM
2K2 TLS's Avatar
On a 8 inch rim the ideal tire size would be 245's but your right i dont think it would fit perfectly. I was about to go 245's but i didnt want to risk rubbing and having to cut plastics in my fender. Your offset has alot to do with it too, hopefully its +50 or higher.
If your looking at your car from the rear and you see your two rear tires: NORMAL (not lowered)-----> l l
When tires "BUTTERFLY"-----------> / \
Tires butterflying also causes premature wear on the inside of the tire.
Old Feb 24, 2002 | 10:30 PM
Holyman's Avatar
Question 19x8 so what would be an good offset?
Hey guys, it seems like the 19 inch rims are more trouble in the long run. But i have seen them on TL-S and they look so awsome. What would be an nice offset if i was to go with an 19x8 but i want it to be a little shy of flush with the fender? And does it matter if it was in the front or the back?
Old Feb 25, 2002 | 10:04 AM
is300eater's Avatar
thanks for that info... as for my offset goes... it's at 51mm (19X8). That should be okay, yah?
Old Feb 25, 2002 | 10:11 AM
Crzy Acura's Avatar
Please keep me informed, cuz thats the exact setup im going with... 19x8 with a 51offset!!
Old Feb 25, 2002 | 11:24 AM
2K2 TLS's Avatar
IS300eater: You should be just fine, your offset is good. Rims are .5 inches too wide to be funtional on our cars but that ok.
CrazyAcura: Your setup sounds like IS300's you should be ok as long as your rubbers are no large then 235 35 r 19. Just be VERY careful on potholes because even with 235's, your 8 inch wide rim is made to fit a 245 perfect thus 235 might be slightly skimpy and lip of rim will stick out futher then the tire. If your car "butterfly's" then i would watch the inner lip, thats how i bent my old rims. I had 225's on a 7.5 inch rim, should have been 235 and it was butterflying.
Old Feb 25, 2002 | 12:09 PM
Crzy Acura's Avatar
What do i have to do to fit 245s?
Old Feb 25, 2002 | 12:13 PM
Holyman's Avatar
hmm
yeah, what would rub if we got 245s on 19x8? the fender or the inside?
Old Feb 25, 2002 | 01:02 PM
Closer's Avatar
I've had 19s and 18s. The only rims I've had bend were
the 18s which bent twice on the same wheel.
Old Feb 25, 2002 | 01:03 PM
Closer's Avatar
Re: hmm
Depends on your offset and profile. But, quite possibliy both.
Old Feb 25, 2002 | 01:09 PM
Closer's Avatar
Butterflying = Negative Chamber. It means you need an alignment.
Old Feb 25, 2002 | 02:35 PM
is300eater's Avatar
Re: Re: hmm
so, what do YOU think about my set up? I have 19X8, with 51mm offset, and 1.75 inches lowered in front and back... Do you think I can get by with 245 tires?
Old Feb 25, 2002 | 02:51 PM
Holyman's Avatar
Would this rub?
Hey guys. Another question, If i get 245 x 19 x 8 x 50+ offset with out lowering the car. Can i get pass with out any rubbing?
Old Feb 25, 2002 | 04:09 PM
Closer's Avatar
Re: Re: Re: hmm
No. I would get 235/35 max. Besides, 245 would be too much
rubber for an Acura. You don't want that muscle car tire buldge.
235/35-19 is almost exact same size diameter as stock too.
Old Feb 25, 2002 | 06:48 PM
2K2 TLS's Avatar
crazyacura: Definitly trim the plastic tabs in your fenderwell, and maybe even roll your fenders. I wouldnt do it.
Old Feb 26, 2002 | 08:12 AM
NSX4dr's Avatar
Original Member #81
235s are designed for a 8-8.5" rim......
and I run 34lbs of air no more...you run more and you'll start wearing you're tires unevenly....
Old Feb 27, 2002 | 05:40 PM
Slammed99TL's Avatar
I noticed you are lowered 3" I was wondering how long tires last you because I also have a 3" drop & I go through tires like crazy. I just took off my 19's that I got just 2 weeks ago that had brandnew Proxes FZ4's because if I left them on for another month they would be bald I am gonna higher the car a little to see if it corrects my camber a little. Also I just got my alignment done yesterday for the first time in 1 year do you think that may have been a factor in my tire wear.
sorry for all the questions
Old Feb 27, 2002 | 08:33 PM
2K2 TLS's Avatar
235's are NOT ment for 8-8.5 inch rims. An 8 inch rim is ment to have 245's and the 8.5 is ment to have 255's. 235's will be too small to properly cover the 8 inch rim, your tires will have a slight slant in order to fit that size rim and 8.5 forget about 235's on a 8.5. If you have 235's on a 8 or 8.5 inch rim take the rim off and look at it fro the top and you will see what i mean by tire will have to stretch in order to fit it.
Old Feb 27, 2002 | 08:34 PM
2K2 TLS's Avatar
dont get me wrong it will fit, but its not ideal.
Old Feb 27, 2002 | 10:59 PM
Crzy Acura's Avatar
I know what you are saying.. i seen cars with tires that dont look like they fit the rim.. like you can see the edges of the rims rather than the tire itself.
Old Feb 28, 2002 | 12:00 AM
Bfor3's Avatar
Hey Crzy Acura which rims did you decide on??? I wanted to go 19x8 as well but the rim I wanted is only +45 offset and I don't think I want any trouble w/ anything rubbing!! because I want to slam it too!!! From all the posts on 19" rims and people saying if they rubbed or not, it does seem like a 19x8 W/ +50 to +55 offset is the best period to not rub but if someone wants to try 245-35 tires, the worst that should happen is you should have to trim that plastic tab in the back!!! But then again 245-35 would slow the car down 4 sure. It's true, 2 much rubber for acura's.
Also slammed99TL your alignment will definately help but you can also buy the camber kit sold here to correct most of your camber problem, that would help a lot
Old Mar 1, 2002 | 01:52 AM
wiggingboy's Avatar
DO NOT GET 245 series tires...i have them on my HRE's and it rubs badd. even with my fenders rolled..so dont think about it.
oo7spy
Jun 19, 2023 12:48 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
urbtsx
Mar 4, 2017 06:53 PM
usdmJON
ILX Tires, Wheels & Suspension
Nov 13, 2015 07:06 PM
