Offset and Tire size??
I am looking to pick up a set of wheels and want to know which offset I should go with..
The wheels are 19"x8.5" and I want to run a 255/35/19 tire. I can choose either a 32 offset or a 38 offset. Currently I am on A-Spec suspension. I may decide to change it out for a bigger drop.
Which offset should I go with so I won't rub even with passengers. Obviously I want to get the most aggressive offset I can use.
94 DC4 RS LSV/Turbo
if you went with the +32 you'd be super aggresive and it would look awesome... if you lowered it you'd have to find a custom negative camber setting that will prevent rubbing with the fenders... but if you rolled the fender you'd need to camber less... wheel tucking would require some more negative camber
imo I would go with the +38 which is still a very aggresive look with a 245 series tire... if for some reason you'd like to go more aggressive a 3mm spacer all around (harmless) would surely fix the look.... and is a method that can be reversed as opposed to rolling the fenders or getting the +32 offset
Originally Posted by MICHAELBPR
+32 with 245 in the front will rub if the car is to low. (My experience with 8.5x20 +32)
Originally Posted by PriMo718
What were you dropped on? How much was the drop? Did the rear rub?
The car was that low in the front for about 2 days. It was rubbing everywhere.
nuldabz
Sep 3, 2015 05:49 PM
Mugen TSX
Eastern Canada
Sep 1, 2015 11:05 PM
