Noise when going over bumps with Aspecs...
I have an 04 Base TL (non brembo) wiht stock suspension.
It has 80k on the clock.
I had the stock 17" rims on it for as long as I've owned the car.
I just bought 18x8.5 Aspec rims with Toyo 245/40/18 tires.
Once I installed them and test drove it, everytime I go over a bump there is a little "ping/small knock" noise coming from the passenger side...
I don't know if it's coming from front or rear yet, but when I punch the sidewall of the front passenger tire, it make a weird ping noise...could a belt inside the tire be messed up and causing this or do you think it's more suspension related?
I don't see any damage to the rims at all, and the tires visibly look perfect. I don't think I had the noise with the stock 17s but I am going to swap them out and drive around to see if I hear it...
Has anyone ever had noise due to a bad belt inside the tire?
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
