Nitrogen Air
Old Feb 24, 2009 | 02:25 PM
jvinhj240's Avatar
Nitrogen Air
Have anyone put nitrogen air to your tires? Where do you bring them to have it done? I am thinking convert to Nitrogen air. Thanks
Old Feb 24, 2009 | 02:39 PM
JMillerUA6's Avatar
Chapter Leader (New England)
Taken from straightdope.com.....
Most tires are filled with compressed air, which when dry consists of about 78 percent nitrogen, 21 percent oxygen, and 1 percent other gases by volume. Water vapor (humidity) can make up as much as 5 percent of the volume of air under worst-case conditions. Filling your tires with nitrogen mainly does two things: it eliminates moisture, and it replaces skinny oxygen molecules with fat nitrogen molecules, reducing the rate at which compressed gas diffuses through porous tire walls. That means, theoretically at least, that a tire filled with nitrogen retains optimal pressure longer, leading to more uniform tire wear and better gas mileage. The commonly quoted figure is that tires inflated to 32 psi get 3 percent better mileage than at 24 psi.
http://www.straightdope.com/columns/...instead-of-air
I don't see a need.
Old Feb 24, 2009 | 03:01 PM
6spdtl-s's Avatar
Nismo TL yo!
search....there was a thread about this a few weeks ago.
Old Feb 24, 2009 | 04:30 PM
Will Y.'s Avatar
Registered but harmless
It's just pure nitrogen-- tire shops charge for nitrogen from "Nitrofill." Costco uses nitrogen to fill its replacement tires, and it's free/included in the tire cost.
However, as JMiller noted, air is already 78% nitrogen, and most benefits of pure nitrogen are practically undetectable for street-driven cars.
I wouldn't bother.
Old Feb 24, 2009 | 04:42 PM
msala524's Avatar
08 TL-S NBP
I wouldn't bother.
agreed, I had it on and it did help but was too much of a hassle. Every time I hit a bump and some air escaped I could only fill it with nitro which is very rare so I just put air back in it and said forget it!
Old Feb 24, 2009 | 08:27 PM
avs007's Avatar
I wouldn't bother.
Getting rid of moisture is pretty significant tho. I accomplish the same thing with my own compressor and an inline line dryer to remove moisture. Water vapor in the air causes big pressure variances with temperature as it evaporates and condenses.
At the local gas station, they had so much moisture in the air tanks it was rediculous... You could actually soak your hands in water by sprayig the air on it.
Old Feb 24, 2009 | 09:29 PM
Bearcat94's Avatar
AZ Community Team
Q:
So if the air in your tires now is 78% N2, how do get the other 22% of O2, etc out to have a "Nitrogen Fill"?
A:
You don't, ever, get 100% N2. Can't be done unless you fill your tires in a vacuum.
IMHO, N2 is a waste of time for a daily driver. Small improvement in pressure with temp variation and in maintaining pressure over time, but if you pay attention to oyur TPMS and/or check pressure from time-to-time, it's a total waste.
Old Feb 24, 2009 | 10:23 PM
Piotr_W's Avatar
Originally Posted by Bearcat94
Q:
A:
and too expensive
Old Feb 25, 2009 | 02:20 AM
avs007's Avatar
Q:
Like I said, you can get 99.99% the benefit of N2, by simply getting your own air compressor, and installing a line-dryer, which you can get for < $20.
The improvement in pressure variation was noticeable to me... I used to get annoyed with the TPMS reported low pressure when it was cold, but getting back in the normal range when the tires heated up... When I stopped getting air at the gas station (which I noticed had a LOT of water in it), and got my own air compressor (for other reasons), and installed a line dryer... I stopped getting such drastic pressure variations with temperature, and the TPMS stopped getting on my nerves.
Old Feb 25, 2009 | 06:59 AM
Bearcat94's Avatar
AZ Community Team
Wish I had a compressor.
Old Feb 25, 2009 | 09:27 AM
Audioholics's Avatar
I paid the dealer a one time fee of $50 and I have nitro for life on my tires anytime I need it. Personally I think its worth it b/c the tires seem to hold their pressure longer and I think it does feel a bit smoother. Plus they gave me cool nitro caps for my wheels
Old Feb 25, 2009 | 12:58 PM
BEAR-AvHistory's Avatar
I have it in the 20" tires on my Expedition (freebee on the purchase) & it seems to work well. Have yet to add after 10K miles (summer-fall-winter). Also comes with free flat fix road, hazard etc.
Also have a compressor with a dryer for the other cars. I don't think I would pay extra for it but would not turn it down if its was offered as an incentive to buy.
Old Feb 25, 2009 | 04:18 PM
georgegiorgio's Avatar
G Force
True, it holds the pressure way longer.
Like 6 to 8 months.
It'll drop during winter, but once back in warmer days, it'll go up again and maintain previous pressure.
I had mine done all 4 wheels within a week after I got my TL-S
Old Feb 25, 2009 | 04:47 PM
Ramrodthrusterpuppy's Avatar
Works well in the Winter...Costco filled mine when I bought my Michelin Alpins from them and tops them up free of charge. But agreed with the rest, I wouldn't pay extra for it.
Old Feb 25, 2009 | 06:11 PM
Xiomaro's Avatar
1st 3g Turbo TL-S
Talking
i get my nitro free cuz i'm special
Old Feb 26, 2009 | 07:26 AM
SpecialFX's Avatar
If nitrogen-filled tires make you feel better go for it. As the linked article - and many, many others - will tell you, for street cars there is negligible benefit other than the psychological.
Old Feb 26, 2009 | 07:54 AM
claydus's Avatar
If it's 40 or below around my area and my car has sitting all night long... My TPMS goes crazy in the morning saying that i have 29 PSI in all 4 tires. However, within five minutes driving time the warning goes away. This is really annoying at times. Not sure if my dealer filled me up with Nitrogen air when i bought the car a month ago.
Biggie_B
May 27, 2025 05:51 PM
SidhuSaaB
May 30, 2020 12:40 AM
tsx_boy
Dec 13, 2019 08:33 PM
rcs86
Aug 2, 2016 06:52 PM
hashbrown
Sep 29, 2015 12:13 PM
