New Wheel/Tire specs thread with pics
Old 09-03-2015, 02:29 PM
  #1001
strorm trooper's Avatar
1. Brand of Rim - Fast Kosoku
2. Rim size - 19x8.5 front, 19x9.5 rear
3. Offset - +25
4. Brand of tire - Sigma Velozza
5.Tire size - 225/35/19 front 235/35/19 rear
6. Drop Type and Amount - Tein SS Coilovers 3" drop all around
7. Do they rub - On Big Bumps
8. Transmission type - Auto
Old 09-08-2015, 06:42 AM
  #1002
uvb4less's Avatar
Love it
Old 09-08-2015, 07:20 AM
  #1003
uvb4less's Avatar
I like the size of our 3g TLS. the rims really go well with it
Old 10-13-2015, 09:54 AM
  #1004
FilmerTyler's Avatar
1. Brand of Rim - WatercooledIndustries (WCI) CC10
2. Rim size - 18x9.5 all around
3. Offset - +35, with spacers +15 for front, and +2 in the rear
4. Brand of tire - Economics, some cheap brand guy before had
5.Tire size - 205/35/18
6. Drop Type and Amount - Bags, A lot..
7. Do they rub - Only while turning when riding low
8. Transmission type - Manual
Old 10-16-2015, 06:20 AM
  #1005
Boosejars's Avatar
  1. Brand of Wheel: Varrstoen MK2
  2. Wheel Size: 18 x 10 squared
  3. Offset: +25 squared
  4. Brand of Tire: Achilles ATR Sport 245/40
  5. Drop Type and Amount: BC Coilovers 12F/10R, only rubs on dips (have only driven about 100 miles so far on this set up), current height is 24" ground to fender lip in front, 24.5" in the rear, i have rolled/slightly pulled the fronts and rears, and shaved the tabs
  6. Transmission: 5-spd slushbox
before and after - XXR 530s 18x8.75 et35 to the new Varrstoens
I took these shots, right after I got the wheels home and mounted them up, so dirty car lol...will be taking better pics over the weekend and will update!
Old 10-23-2015, 03:47 PM
  #1006
Andrew
VisualEchos's Avatar
*Waits patiently*
Boosejars (10-24-2015)
Old 10-24-2015, 12:13 AM
  #1007
Boosejars's Avatar
Originally Posted by VisualEchos
*Waits patiently*
hahaha
Old 10-24-2015, 12:23 AM
  #1008
Boosejars's Avatar
Some updates - still a dirty car - toe has been set to zero, camber is natural -1.6 in front, and -2.4 in the rear...not running any camber kits yet.
Old 10-27-2015, 11:28 AM
  #1009
marcar74's Avatar
1.Brand of Rim - Motegi
2.Rim size (diameter and width) - 19" x 10"
3.Offset - +45mm(f) +35mm(r)
4.Brand of tire - Uhtso
5.Tire size - 265/30/19
6.Drop Type and Amount - Function/Form - not for sure how much
7.Do they rub - Rubs in front tuning into my driveway
8. Transmission type (use of spacers if 6MT) - auto
Old 10-27-2015, 11:38 AM
  #1010
marcar74's Avatar
[http://imageshack.com/a/img908/5215/BrOftb.jpg]
[http://imageshack.com/a/img907/2858/t4e7Jm.jpg]
[http://imageshack.com/a/img903/3545/5XF1mx.jpg]
[http://imageshack.com/a/img907/739/BUQzUW.jpg]
Old 10-27-2015, 11:55 AM
  #1011
marcar74's Avatar
My 2008 TL
Attached Thumbnails New Wheel/Tire specs thread with pics-20151024_183011_resized.jpg   New Wheel/Tire specs thread with pics-20151024_183044_resized.jpg   New Wheel/Tire specs thread with pics-20151024_183111_resized.jpg   New Wheel/Tire specs thread with pics-20151024_183140_resized.jpg
Old 04-29-2016, 01:41 PM
  #1012
xdmds's Avatar
1.Brand of Rim - Enkei RPF1
2.Rim size (diameter and width) - 18" x 9.5"
3.Offset - 38mm
4.Brand of tire - Michelin Pilot Super Sport
5.Tire size - 245/40/18
6.Drop Type and Amount - ASPEC suspension
7.Do they rub - Full lock when backing up.
8. Transmission type (use of spacers if 6MT) - 5AT no spacers
Old 05-02-2016, 10:05 AM
  #1013
Andrew
*Just an update post since I can't edit my original.
1.Brand of wheel - Miro 112 (custom Hyper Silver finish by Detroit Wheel and Tire)
2.Wheel size (diameter and width) - 18 x 9.5
3.Offset - +40
4.Brand of tire - Goodyear Eagle F1 AS2
5.Tire size - 265/35
6.Drop Type and Amount - 1 finger, front and rear
7.Do they rub - Never
8.Camber F/R - -1.5° / -1.5°
9. Transmission type - AT
*Slight roll in the rear, and the 265 tire I'm running is about .4" narrower than a normal 265, which is why it fits perfectly in the front without much negative camber.
Tail Happy.
by Andrew Thompson, on Flickr
Old 05-27-2016, 01:46 PM
  #1014
baddestm0nkey's Avatar
1. Brand of Rim - Stance SC-5
3. Offset - +35 Front, +40 Rear
4. Brand of tire - Hankook Evo v12
5.Tire size - 235/35/19 front 245/35/19 rear
6. Drop Type and Amount - Tein Basis Coilovers 2" drop all around
7. Do they rub - Nope
Attached Thumbnails New Wheel/Tire specs thread with pics-img_0341.jpg   New Wheel/Tire specs thread with pics-img_0342.jpg   New Wheel/Tire specs thread with pics-img_0343.jpg   New Wheel/Tire specs thread with pics-img_0264.jpg
Old 05-31-2016, 11:19 PM
  #1015
SlammedCRXsi's Avatar
Will these fit?
Old 06-05-2016, 10:13 PM
  #1016
BiggPinyot's Avatar
Originally Posted by SlammedCRXsi
Will these fit?
You should be fine from seeing what others are running on here. You may have to roll, but I'm not 100% sure.
Old 07-30-2016, 10:27 AM
  #1017
NVER ENF's Avatar
1.Brand of Rim - Varrstoen
2.Rim size (diameter and width) - 19" x 9.5"
3.Offset - 22mm
4.Brand of tire - Nitto 555
6.Drop Type - Tein Strett Advance
7.Do they rub - Very rarely. Only in the front.
8. Transmission type (use of spacers if 6MT) - 5AT (no spacers)
Old 08-11-2016, 04:28 PM
  #1018
oneeb97's Avatar
Mannn I was so excited to see all these setups, but I can't see majority of the pictures
Old 08-15-2016, 07:38 PM
  #1019
Nemowuner's Avatar
1.Brand of Rim - Ron Jon sport Inspyre I
2.Rim size (diameter and width) - 19" x 8.5"
3.Offset - 42mm
4.Brand of tire - Sunny / SN3970
6.Drop Type and Amount - Coil overs - tucked in a bit with a slight fender roll.
7.Do they rub - No rubbing at all
ATLS_666 (08-16-2016)
Old 08-21-2016, 07:33 PM
  #1020
tody009's Avatar
Brand- XXR 527 forged
Rim size - 18x9
Offset +35
Brand of tire- pirelli
Size- 245/40/18
Drop type- tein h tech springs on koni str.t orange
Do they rub- not at all
Transmission - 6 speed. 5mm spacers in front to clear brembos
wilspainar (08-23-2017)
Old 08-25-2016, 08:47 PM
  #1021
Aargh-ura's Avatar
Brand of Rim - 08 Base TL Stock
2.Rim size (diameter and width) - 17" x 8"
3.Offset - None
4.Brand of tire - Yokohama YK580
5.Tire size - 235/45/17
6.Drop Type and Amount - Tein SA Coilovers - 2" ish
8. Transmission type (use of spacers if 6MT) - AT no spacers
9.
Old 09-04-2016, 10:29 PM
  #1022
BiggPinyot's Avatar
A lot of nice cars out there with really clean set ups. Here's mine... Not exactly what I want, but it will do for now. I couldn't pass up the deal on the wheels and tires. Hoping to go wider eventually, if ever.
1.Brand of Rim - MB Weapons
2.Rim size (diameter and width) - 18x9
3.Offset - 38mm
4.Brand of tire - Barum Bravuris 3
5.Tire size - 255/35r18
6.Drop Type and Amount - Tein Flex about 1.5" all the way around. Estimate.
7.Do they rub - No rubbing even if not rolled, but rolled in the rear just for peace of mind.
8. Transmission type (use of spacers if 6MT) - 6MT No spacers
9. Picture
Old 09-21-2016, 05:45 PM
  #1023
Al_
Al_'s Avatar
All these cars look absolutely stunning, can't wait to get wheels on my 3G.
Old 09-22-2016, 06:19 PM
  #1024
BiggPinyot's Avatar
Are you planning to lower? Or keep it at stock height?
Old 09-22-2016, 07:09 PM
  #1025
Al_
Al_'s Avatar
Eventually planning on lowering it but nothing crazy probably H&R springs, would like to get a lip kit first though.
Old 09-23-2016, 09:05 AM
  #1026
Tlarbino's Avatar
Setup
1.Brand of Rim - MB motorsports VR-5
2.Rim size (diameter and width) - 18x8 F 18x9 R
3.Offset - 38mm Front. 35mm REAR
4.Brand of tire -
5.Tire size - 225/40/18 F & B
6.Drop Type and Amount - tanabe. 1.5 f 1.8 r After powder coating.
7.Do they rub - None
8. Transmission type (use of spacers if 6MT) - none. 5at
9. Picture
Current setup after lots of research. Thanks to all the info on acurazine.
1.Brand of Rim - ARK DESIGN R8's
2.Rim size (diameter and width) - 18X9.5 ALL
3.Offset - 40mm
4.Brand of tire - 123 S Achilles
5.Tire size - 265/35/18
6.Drop Type and Amount - Tanabe 1.5" F / 1.7" R
7.Do they rub - rolled rear fenders
8. Transmission type (use of spacers if 6MT) - 5AT No spacers
9. Picture
Old 09-23-2016, 09:43 AM
  #1027
Al_
Al_'s Avatar
3.Offset - 40mm
9. Picture
[/QUOTE]
Old 09-23-2016, 09:45 AM
  #1028
Al_
Al_'s Avatar
[/QUOTE][/QUOTE]
Sorry to post twice, phone is being difficult. But mean to say looks clean! Only lowered on springs too 👌🏼
Old 10-18-2016, 10:04 PM
  #1029
JemmieN's Avatar
1.Brand of Rim - Work Emotion XD9
2.Rim size (diameter and width) - 17 x 9.5
3.Offset - (+17mm)
4.Brand of tire - Pirelli P-Zero
5.Tire size - 225/45/17
6.Drop Type and Amount - Coilovers, shaved rear fenders, pulled front fenders
7.Do they rub - On full lock, big dips/humps
8. Transmission type (use of spacers if 6MT) - 6spd, no spacers.
1.Brand of Rim - MB Battles
2.Rim size (diameter and width) - 18 x 9.5
3.Offset - (+12mm)
4.Brand of tire - ??? Can't remember
Old 10-27-2016, 05:55 PM
  #1030
srg818's Avatar
1.Brand of Rim - XXR 530
2.Rim size (diameter and width) - 18x8.75
3.Offset - +20
4.Brand of tire - Continental DWS06
6.Drop Type and Amount - H&R Sport kit 50106 - Front 1.4 Rear 1.3
Old 11-28-2016, 10:40 AM
  #1031
Perdomes's Avatar
I know this is very late, but do you know by how much did you drop in front and rear?
Old 11-28-2016, 02:20 PM
  #1032
eastcoastguy's Avatar
Who are you asking this?
Old 11-28-2016, 07:00 PM
  #1033
9th Gear
Connor_P's Avatar
1.Brand of Rim - Axis Sport XM
2.Rim size (diameter and width) - 18X8 ALL
3.Offset - Unknown, car came with the rims
4.Brand of tire - Pirelli P Zero Nero All Season Run Flats
6.Drop Type and Amount - None
7.Do they rub - Not so far, only have a few miles on them
9. Pictures will come later once I clean the wheels
Old 12-07-2016, 05:55 PM
  #1034
BiggPinyot's Avatar
Man, it must take a long time to clean them wheels. J/K.
Old 01-13-2017, 05:01 PM
  #1035
Al_
Al_'s Avatar
Dude I knew I totally have seen your car before, I live in Loma Linda as well. Usually see your car on Mountain View and Redlands Blvd. Do you know of any meets out in our area?
Old 01-14-2017, 10:26 PM
  #1036
BiggPinyot's Avatar
Is this in Redlands off of San Bernardino Blvd? Across from the new 24 Hour Fitness? Yay!!! A local member! Haha.
Old 01-15-2017, 01:21 AM
  #1037
Al_
Al_'s Avatar
yea dude!
Old 04-22-2017, 11:11 AM
  #1038
She'sCalledDrGrey's Avatar
1.Brand of Rim - 18X8 ENKEI PERFORMANCE SS05 HYPER GREY
3.Offset - 38mm
4.Brand of tire - Goodyear Eagle F1 Asymmetric 2
5.Tire size - 235/45/18
7.Do they rub - No
4drturbo (01-13-2020)
Old 04-30-2017, 12:07 PM
  #1039
Desert Life Sucks!!
sauceja's Avatar
1.Brand of Rim - VIP Modular
2.Rim size (diameter and width) - 19x9.5 / 19x10.5
3.Offset - +25
4.Brand of tire - Federal 595
5.Tire size - 225/35 FR - 235/35 RR
6.Drop Type and Amount - ISC N1 Fenders rolled slight pull
7.Do they rub - The rears do on harsh bumps and uneven roads
8. Transmission type (use of spacers if 6MT) - 6spd, 3mm spacer needed in front or will need to shave calipers some (not for the weak at heart)
9. Camber - I was running these at zero toe zero camber
Old 05-01-2017, 11:42 AM
  #1040
SL33per's Avatar
Greetings my fellow Acura enthusiasts. I'm getting conflicting information. Does anyone know for sure if the "XXR - 530" will fit the 3rd gen type-s models?
Quick Reply: New Wheel/Tire specs thread with pics
