New Wheel/Tire specs thread with pics
Old 08-14-2014, 06:55 PM
  #961
Speedrow's Avatar
1.Brand of Rim- Niche 130's
2.Rim size (diameter and width) – 19x9.5 all around
3.Offset- +35 all around
4.Brand of tire – Federal super steel 595
5.Tire size - 25/35/19 all around
6.Drop Type and Amount – stock
7.Do they rub – not at preset ride height
8. Transmission type - 5AT no spacers
Old 09-01-2014, 01:55 PM
  #962
Bswain321's Avatar
1.Brand of Rim - Varestoen
2.Rim size 18x9.5 F 18x10.5 R
3.Offset - +25 front ( trying to find out rear
4.Brand of tire - Genral
5.Tire size - 245/40/18
6.Drop Type and Amount - tein advanced 1.5 drop
7.Do they rub
8. Transmission type 5AT for a type S with brembo
Old 09-12-2014, 09:30 PM
  #963
7th Gear
05_TX_TL's Avatar
Originally Posted by yoks032rs
1.Brand of Rim -(Miro) Powder coated stone Bronze
2.Rim size - 18X9.5
3.Offset - +40 square but added 5MM spacer for the rear.
4.Brand of tire -Goodyear f1 asymmetric 2
5.Tire size -245/40-18
6.Drop Type & Height - TEIN BASIC 2'' drop F/B
7.Do they rub - No rubbing
8.Transmission type - 5AT
[IMG]
[/IMG]
Was wanting to go with those Miro wheels myself and Powder Coat them Hyper Black but found these for $300 and couldn't pass them up. Also have 245/40R18 Nitto INVO tires which I LOVE! I feel like they need spacers but unsure how much... 25mm maybe??? Thoughts please.
Old 09-13-2014, 08:35 AM
  #964
BiggPinyot's Avatar
Well I'm sure 20mm or 25mm should be fine. And honestly, great pick up for $300. Hopefully one day I will be able to post on here. I am long from it.
Old 10-09-2014, 03:26 PM
  #965
blackjackmon's Avatar
Pulled and cambered for the new wheels.
Weds Bazreia's in 19x10.5 and 19x11.5. Added 20mm spacers all around making it a -5 offset. Stretched 225/35/19 up front and 245/35/19 in rear.
Modassir (10-20-2014)
Old 10-09-2014, 03:28 PM
  #966
Hell yeah bro! stoked to see this in Sacramento
Old 10-18-2014, 01:44 PM
  #967
tomlinsonj's Avatar
I have ASPEC wheels and run 245/40/18 as well. Check my progress thread for how they look with 15mm front and 20mm rear spacers.
Old 10-20-2014, 07:13 PM
  #968
Modassir's Avatar
Soooo effing niceeeee You make me wanna go air ride
Old 10-20-2014, 07:18 PM
  #969
Modassir's Avatar
1.Brand of Rim- MB Battles
2.Rim size (diameter and width) – 17x9.5 + 15
3.Offset- +15 Square
4.Brand of tire – Yokahama S-Drive
5.Tire size - 215/35/17
6.Drop Type and Amount – Function & Form Type I not sure how much of a drop
7.Do they rub – Not unless it's a hard turn with bumps
8. Transmission type - 6MT No spacers, clears BBK
Old 10-31-2014, 07:17 PM
  #970
Abyss Beauty
jjjoootttaaa's Avatar
1.Brand of Rim- Concept One CS-16
2.Rim size (diameter and width) – 19x10
3.Offset- +20; +5 & 0 with spacers.
4.Brand of tire – Achilles ATR
5.Tire size - 225/35/19
6.Drop Type and Amount – BC coils w/ custom rates; A lot
7.Do they rub – Barely
Old 11-12-2014, 01:24 PM
  #971
9th Gear
Oscar E's Avatar
1.Brand of Rim- Niche Concourse
2.Rim size (diameter and width) - 20x8.5
3.Offset - 38mm
4.Brand of tire - Nankang
5.Tire size - 255/30/20
6.Drop Type and Amount - none
8. Transmission type (use of spacers if 6MT) - 5AT
Old 11-15-2014, 06:50 PM
  #972
9th Gear
envy's Avatar
1. Brand of Rim - Rays Forged (370 z nissian rim)
2. Rim size - front 19x9 / rear 19x10
3. Offset - +47 front +30 rear
4. Brand of tire - pirelli p zero
5. Tire size -245-40-19 fronts - 275/35/19 rears
6. Drop Type & Height - Stock (rear has 2 shims each side)
7. Do they rub - rubbing on turns... (70 mph on a bend) and 2 people in rear on a dip
8. Transmission type - auto
TripleLex (04-13-2016)
Old 12-03-2014, 12:28 PM
  #973
3rd Gear
moesalamah's Avatar
xxr 530 tein coils
Old 12-30-2014, 01:23 AM
  #974
aznxstylez's Avatar
Originally Posted by 05_NBP_TL
I have the same setup. It requires some camber
Did you sell them? Would you be willing to run 225-35 tires? Thats what I have and dont have any
problems with my setup. rolled
fenders, -2.5 degrees camber, lowered 2.5 inches
Do you have cambers from front to back or just the back
Old 01-01-2015, 02:13 PM
  #975
daciss's Avatar
Originally Posted by Slayer-33
Can I please have your car bro? I love it lol.
Old 01-01-2015, 02:19 PM
  #976
daciss's Avatar
Originally Posted by markp6mttl
1.Brand of Rim - TSW Interlagos
2.Rim size - 18X9.5
3.Offset - +40
5.Tire size -265/35/18
6.Drop Type & Height - TEIN Street Flex 13" Hub to Fender Gap
7.Do they rub - No rubbing, Slight roll on rear
8.Transmission type - 6MT, no spacers needed, tons of room for Brembos
Old 03-31-2015, 09:15 AM
  #977
9th Gear
Polishacorn's Avatar
1.Brand of Rim - Avant Garde M580
2.Rim size - 19X8.5
3.Offset - +35
4.Brand of tire -Bridgestone SO4
5.Tire size -245/35/19
6.Drop Type & Height - TEIN Street basis 25" ground to fender
7.Do they rub - only in reverse on inner plastic fender when full lock
8.Transmission type - 5AT, Type S, close fit to brakes
Old 03-31-2015, 10:18 PM
  #978
Eschott1985's Avatar
Talking
1.Brand of Rim - FK Ethos
2.Rim size - 20X8.5
3.Offset - +35 (all around)
4.Brand of tire - falken azenis pt-722
5.Tire size -235/30/20
6.Drop Type & Height - Stock with A-Spec kit
7.Do they rub - Not one bit
8.Transmission type - 5AT, Base
Old 04-02-2015, 07:23 PM
  #979
1985bmxtl's Avatar
1 rim brand xxr531
2 rim size 19×8.5 19×10
3 offset +35 all round
4 tire brand ohtsu fp8000
5 tire size 235 35 19 255 35 19
6 drop tein street advanced still could go lower
7 do they rub rolled all fenders still rub inner front fender liner just sometimes
8 trans 5at
Old 04-08-2015, 05:21 PM
  #980
JD TL-S's Avatar
Need new pics
Old 04-13-2015, 01:51 PM
  #981
Needs a 930
BeezleTL85's Avatar
Will a 245x40x19 on a 19x8.5? I know a 235x40x19 will fit for sure but the price on those are like 225-300 from what im looking at vs the 245's are "regularly" priced, basically all under 200 per
Old 04-13-2015, 09:48 PM
  #982
1985bmxtl's Avatar
245s will look meaty on a 8.5 and they will throw your spedo off because there taller especially with a 40 series tire.i would go with 235×35×19
Old 04-26-2015, 06:28 PM
  #983
Needs a 930
BeezleTL85's Avatar
1. Brand of Rim - Stance
2. Rim size - 19x8.5 all around
3. Offset - +35
4. Brand of tire - Michelin Pilot Super Sport
5.Tire size - 235x35x19
6. Drop Type and Amount - ISC, not sure on amount.
7. Do they rub - Only when I enter my steep driveway.
Undying Dreams (09-05-2015)
Old 04-29-2015, 09:54 AM
  #984
Joseph Stansbury's Avatar
Originally Posted by Houston
19X9.5 +35 all around with 225/35 & 235/35 I had to use 5mm spacers to clear the Brembos.
I have H&R coilovers, but I'm not really sure how much of a drop compared to stock height. I just measured 20mm from bottoming out the coils.
OMG these look amazing! Do they rub?
Old 04-29-2015, 11:24 AM
  #985
Originally Posted by sonny@tirerack
Wow!
Nice!
Old 04-29-2015, 11:37 AM
  #986
Originally Posted by VisualEchos
1.Brand of wheel - Miro 112
2.Wheel size (diameter and width) - 18 x 9.5
3.Offset - +40
4.Brand of tire - Conti DW
5.Tire size - 255/40
6.Drop Type and Amount - None yet
7.Do they rub - Not that I have found
8. Transmission type - AT
Better pix later.
Elemental. by VisualEchos, on Flickr
Elemental II Desktop by VisualEchos, on Flickr
Dude, there's a tornado coming?
Old 05-01-2015, 11:36 AM
  #987
story.customz's Avatar
1.Brand of wheel - Prodrive Reps
3.Offset - +22
4.Brand of tire - Nankang fronts, Michelin Pilot Sport A/S 3 rears
5.Tire size - 225/40, 235/40
6.Drop Type and Amount - BC Racing - 2.5" front, 2" rear
7.Do they rub - No
Old 05-26-2015, 09:03 AM
  #988
justin.w13.walker's Avatar
1.Brand of wheel - Stock Type-S
2.Wheel size (diameter and width) - 17X 8
3.Offset - +30
4.Brand of tire - continental
5.Tire size - ?
6.Drop Type and Amount - H&R Race Springs & TruHart Struts (2 in)
7.Do they rub - NO
Ceaze (05-14-2017)
Old 05-28-2015, 08:05 PM
  #989
6th Gear
sethman2000's Avatar
Advanti HY Hybris rims
New rims today.
18x8 +35 lowered on Tanabe DF210 springs and Koni yellows. Need to put the fronts down a perch...
m00nix (02-02-2021)
Old 05-28-2015, 08:11 PM
  #990
Driver Mod
2Morrow's Avatar
Looks good!
  #991
6th Gear
Sorry guys... Here is the correct format
Brand of wheel - Advanti HY Hybris
2.Wheel size (diameter and width) - 18x8
3.Offset - +35
4.Brand of tire - Capitol
5.Tire size - 235/40/18
6.Drop Type and Amount - Tanabe DF-210 koni yellow
7.Do they rub - NO
8. Transmission type - 6MT, clears Brembos
Old 05-30-2015, 01:44 AM
  #992
Slayer-33's Avatar
Originally Posted by sethman2000
Sorry guys... Here is the correct format.
Clean AF you sob, very nice.
Old 07-05-2015, 01:02 PM
  #993
TonyN923's Avatar
Brand of wheel - AME Spec-R two piece
2.Wheel size (diameter and width) - 18x9.5F 18x10R
3.Offset - +45 fronts, +42 rear
4.Brand of tire - GT-Radials
6.Drop Type and Amount - Tein S-Tech, about 1.5 all around
7.Do they rub - NO
8. Transmission type - Base Auto
camber set at 1.0 all around, no fender mods, no rubbing even with a fully loaded car. Wheels are flush with the fenders without being "stanced", perfect for my daily driver.
Old 07-14-2015, 08:37 AM
  #994
Andrew
VisualEchos's Avatar
Finally got my BC Racing coilovers on, so I thought I'd update mine. I initially chose the 255/40 (which is a ½" too tall) over the 255/35 because I was going to leave the car at stock height. The tires seemed a bit tall a that time, because of the wheel gap. Once the gap was gone the tires set just perfect.
3.Offset - +40
6.Drop Type and Amount - still settling, I'll let you know
7.Do they rub - No
The following 3 users liked this post by VisualEchos:
4drturbo (01-20-2020), Boosejars (08-12-2015), m00nix (02-02-2021)
Old 07-18-2015, 11:59 AM
  #995
daciss's Avatar
17 inch TSW Interlagos.
Old 07-25-2015, 06:52 AM
  #996
aussie_tl's Avatar
3.Offset - +30
5.Tire size - ?
7.Do they rub - NO
Old 07-25-2015, 06:57 AM
  #997
aussie_tl's Avatar
1.Brand of wheel - XXR 530
2.Wheel size (diameter and width) - 18x8.75
3.Offset - +20
4.Brand of tire - Nankang NS-20
5.Tire size - 225/40/18
6.Drop Type and Amount - Tein SA Coilovers, not sure on drop.
7.Do they rub - NO (rolled rear fenders)
Old 08-05-2015, 07:59 PM
  #998
serpent's Avatar
2.Rim size - 18X9.5
[/IMG]
Wow, nice setup, wheels remind me of the Hellcats:
Old 08-25-2015, 08:11 PM
  #999
AD614's Avatar
3. Offset - +35
Have to say, I'm really loving the setup.
BeezleTL85 (02-13-2016)
Old 08-26-2015, 02:35 PM
  #1000
Spinnin them beats
Acuraluvr's Avatar
1. Brand of Rim - Avant Garde M510
2. Rim size - 19x8.5 front, 19x9.5 rear
3. Offset - +35, +40
4. Brand of tire - Continental DWS
5.Tire size - 245x35x19 all around, minor stretch on back
6. Drop Type and Amount - Tein H spring, .8-1.0 inch drop
7. Do they rub - Nope
Quick Reply: New Wheel/Tire specs thread with pics
