New Tires Installed. Need Help..
![Patriot](https://acurazine.com/forums/images/smilies/patriot.gif)
18" 245/40/18's on the 18" A-Spec rims.
I am in a tight spot based on the odomoter which will be quite inaccurate now..
I heard the the Navi screen can adjust to the new tire & rim size to report the accurate mileage.
Has anyone done this? If so, how?
Any help would be greatly appreciated.
Thank You
GMan
i have the same wheel/tire size. the speedometer/odometer/navi do not need any adjustments. i even had the opportunity to check my spedometer against the radar stations they setup in the residential areas here in NJ. so far 25 on the meter was 25 on the radar.
245/45/18 is still pretty close to the same size as the stock. the difference is fractional if any.
Originally Posted by gman44116
I believe the 245/45's are much closer to standard than the 40's.
If I am correct, I am posting 100 miles when actually it is 97.
3% difference. this could add up.
Does anyone know if the Navi can adjust the dimensions??
235/45 is about the same as a 245/40
245/45 will be taller than a 235/45
TL = Tranny Lubrication
Have to tried: http://www.miata.net/garage/tirecalc.html
With the change from 245/45/17 to 245/40/18 the difference is only 0.1% too slow.
Your speedo shows 60 mph you are actually at 60.1mph.
Originally Posted by 3PUTT
it's really only about a 5mm difference....
235/45/17
[(23.5mm * 1in/2.54cm)*.45]*2 +17in = 25.32in tall
245/45/18
[(24.5mm * 1in/2.54cm)*.45]*2 +18in = 26.68in tall
245/40/18
[(24.5mm * 1in/2.54cm)*.4]*2 +18in = 25.71in tall
so to stay around oem height i would opt for 245/40/18, not a 245/45/18
gman44116 - the diff between bolded heights is not enough to throw your speedo off or affect Navi (Navi should use GPS sampling to know where you are, not by how many miles the car says it has gone. in other words, your Navi should work even if your car is on a flatbed).
Originally Posted by cvajs
yes, but he moved from 17" rims to 18" rims.
235/45/17
245/45/18
245/40/18
235/45/17
245/45/18
245/40/18
My Fault....
that's right!! i was mistaken. my car
That is right!! I was mistaken. I do have 245/40/18 on my SSRs.
tire sizing has always been a game of "try-it, try-another". i find that tires of same size from diff brands are not always the exact same size.
cheers.
and i have to correct my calcs, the answers are correct but the tread widths should have been in "cm" units as opposed to "mm".
InFaMouSLink
10-27-2015 06:51 PM
Billu99tl
09-13-2015 11:30 AM
