Need some opinions on XXR 526!
Old 11-28-2015, 07:29 PM
Tattoofeind05's Avatar
Good to be here an have some questions I hope you all can help out with on rim an tire size "Maybe" some of you have tried. I am not new to the Static/Lowered Life game been doing it for some years now. Just picked up a 05 TL Aspec for cheap an am going to start playing with it. The BIG question.... anyone ran Xxr 526 18x10.5s +20 with a 225/35 stretch on springs or coilovers? Was planning on picking up 4 An doing a little craziness. I believe camber an roll maybe a pull to make it work out, not to big on the Crazy camber. Was wondering if a +20 will fit without hitting anything as far as brake caliper or struts? Didn't have any problem with a +15 on my 09 but only running 20x8.5s. ANY opinions an answers will be appreciated
Old 12-03-2015, 07:59 AM
Boosejars's Avatar
i would run 225/40 - that 35 sidewall is going to small with that stretch...225 will put just sit behind the lip. i know of several running 18x10.5 +25 and no issues - so you'll be in 5mm closer -so 225 will allow you to run fender to lip on lowering and fitment, and the 40 series will provide some added comfort lol. however if you plan to slam and run fender to lip, you need to have some good coils and higher spring rates. you will need to roll and pull in the front, and roll and a slight pull in the rear for fender to lip fitment. as always do a test fitment before mounting the tires to check for brake clearance, however, if you do not have BBK it wouldn't be a problem.
Tattoofeind05 (12-03-2015)
dwb993
07-30-2016 02:59 PM
sockr1
04-20-2016 10:49 AM
N1h1l1ty
3G TL Photograph Gallery
209
12-22-2015 06:00 PM
bersrkr
12-09-2015 08:50 PM
dwb993
11-16-2015 10:21 PM
Quick Reply: Need some opinions on XXR 526!
