need some input!
need some input!
well this is the third time i try to post this so it better work!
guys i wanna know what ya think about size in wheels is size everything basically is what im asking i wanna know if 18's are ok and will they look good or will they look like baby wheels i wanted 19's but the wheel i want seems to only be availible in 18 maybe im wrong but anyways let me know what ya think i also dont wanna roll the fenders and i dont want any rubbing! i also have no idea what a offset is so if ya talking ofset you mind as well speak chinese to me guys pls help! and heres a pic of the wheels u like ?
hey bro, i think those wheelz look good. which car u gonna put em on? i saw ur gallery and all the cars look good. im thinkin the 18's should be perfect, but u unfortunately gotta find out the offset to make sure that they will fit, jus post what the offset number is and im sure people will tell u if they fit or not. im pretty sure if its gonna go on a TL then the offset has to be +45 or larger. hope this helps
YEAH THEY ARE Advan knock-off's... IM NOT INTO SPENDING BIG BUCKS FOR A NAME WHEN THEY ARE SPINING THEY ARE THE SAME AND THEY STILL LOOK HOT WHAT IM ASKING IS ABOUT SIZE I NEED HELP!
for 18's you want at least a 45+ offset.
they will not look like baby wheels, but i would highly reccomend dropping the car to eliminate the wheel gap.
if you do go with 19's, i believe you need at least 47 or 48+ offset. somebody correct me.
Redlinen:
If you get 18x7.5 rims, offset is +45 or higher. Recommended tire size is 225/40/18
If you get 18x8 rims, offset is +50 or higher. Recommended tire size is 225/40/18
If your wheel vendor can't give you the right wheel offset, walk away. Warning: not following the recommendations above will likely increase the chances that your rims will rub (which means you will have to trim your tab, or roll your fenders).
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
