Need replace lower ball joint
http://www.rockauto.com/catalog/raframecatalog.php
MOOG Part # K500117 Frt Susp; Lower $28.99
RAYBESTOS Part # 5051370 Front Suspension; Lower $
41.79
Use this code until 6/26/11 and receive 5% off parts:
55553873520203
Enter the code above in the "How did you hear about us" line.
41.79
55553873520203
They say that the nut size was incorrect. The nut certainly shouldn't keep the part from coming out as threre should be a sleeve or spacer the ensure that it stays in place. Never hear of the lower arm depending or riding on the nut to keep it in place. In fact, the OEM has a clip under the lower arm to secure it in place.
This guy says you have to remove that little race before you can pull out the ball joint. Is that true? And is it difficult? Require a special tool? Thanks..
marcelft
07-10-2018 06:17 PM
