Need Help PLease Look!!!
Old Jun 19, 2002 | 06:37 PM
phat32's Avatar
Question Need Help PLease Look!!!
I am about to order my rims im going to get a set of 19's.what size tire should I run and what kind of offset should I run. I was goin to get 235 35 19 but this guy said it would be to short.I just need some advice.I also have a 2000 3.2 im wondering would it rub when i put the springs on.I would appreciate all the info you guys can give me thanks.
Old Jun 19, 2002 | 08:03 PM
StanMan's Avatar
what rims are you getting? what widths are available? how about offsets? tell us this and we can probably tell you the *best* setup you can get.
Old Jun 19, 2002 | 09:21 PM
phat32's Avatar
im getting the niche f16's in 19's.i dont know what offsets they come in....what should i sak for .im going to order a set of skunk 2's.i am worrying about rubbing let me know
Old Jun 19, 2002 | 09:27 PM
9th Gear
Chack this site out for tires. I think that it will be helpful.
http://www.miata.net/garage/tirecalc.html
Old Jun 20, 2002 | 02:06 AM
Lawaia's Avatar
Moderator Alumnus
I think you need to slow down and get all your specs before ordering those wheels. There is more to it than ordering a 19" wheel with tires. Do some research first. Trust me, you don't want to find out about offset after you got them mounted and they are rubbing like a SOB! You need to find out what offsets those wheels are available in.
Old Jun 20, 2002 | 10:07 AM
phat32's Avatar
Unhappy oh noo!!
THe rim is a niche f16 19 by 7.5.The rim only comes in a 38 offset will that work.These are the rims that i want and i dont want to order them until i know everything will work. Let me know!
Old Jun 20, 2002 | 10:32 AM
StanMan's Avatar
i got 7.5s with a 42 offset and 225/40/18 tires, and i still rub sometimes after trimming the bumper tab...lowered on prokits. your setup is close to mine, saying if you went with 225/35/19 tires, then you would *probably* rub more than mine since your offset would be 4mm lower. now if you wanted to put on 235/35s, you definitely need a higher offset!
Old Jun 20, 2002 | 03:08 PM
songoku's Avatar
BlingBling INSPIRE 32V
I have 19 X 8 with 49+ offset size tire 235/35/19.
I lowered mine with H&R OE spring and no rubbing after I cut my rear bumper tabs.
Old Jun 20, 2002 | 04:20 PM
phat32's Avatar
WELL HOW MUCH CAN I GET A SET OF LD-1 FOR.I WANT A SET BUT DONT WANT TO PAY TO MUCH.3K IS MY LIMIT. LET ME KNOW. 235-35-19 I HEARD WAS TO SHORT OF A TIRE.CAN SOME ONE GIVE ME SOME INFO.IM REALLY CONFUSED .
Old Jun 20, 2002 | 04:54 PM
songoku's Avatar
Which one? Silver, polished, chrome?
I've got mine from Mike (valuetl) and cost me about 35 including everything. If you want chrome, it's little bit more. Ask him what the prices are.
235/35/19 too short of a tire??
That's the only size we can come up with on 19's. If you you get the correct offset, you shouldn't have to worry about the rubbing.
Old Jun 20, 2002 | 09:39 PM
phat32's Avatar
well i think i am just goin to get a set of 18's.actually im going to get the katana spazio's.they come in a +45 offset,so i think thats gonna be okay.what size tire should i run.the 225 40 18 seems like it is to short.the 235 40 18 seems like it is just right .someone give me some info on what size tire i should run. thanks
