need help with a drop
I just got ronjon legends in 18 inch with 245 tires and they do seem to stick out a little. So im afraid to drop it since im not really sure if im gonna have any problems with rubbing. Im not going for anything bigger then a 1" drop all around.
whats the best way i should do it ... maybe aspec suspens. or something like eibach springs and koni shocks or whatever you guys think its best and also something thats gonna ride nice too
thanx for your help
thanx for your help
A-spec drops .75 inch at the most, and thats with the MT suspension on AT models.
Originally Posted by rondog
pm Dragonlord, he has a similar setup:
You told me that i might have a problem rubbing with 245 tire so im just making sure what i can do since with the more comfortable ride as it is now im not gonna sacrifice it to much with a 1" drop all around...
I think the Eibach prokit springs drop an even 1" all the way around so it would look pretty good on some 18s. IMO, I would probably go about 1.4/1.5 all the way around.
A-Spec suspension gave me a .75 drop, I think its not low enough for when I had my 18s on. But then again, that's just me.
Im pretty sure it would look better then without anything.... i dont wanna put something together ill rather stick with something that is designed for this car as im also looking into it performing better while still retaining some comfortable ride and also a to much of a drop here in NYC not so good
Here I come!
These are 18's with H&R sport springs. That's a 1.4"F/1.3"R drop and 225/45z/r18's. Honestly, I'm not happy with the drop since it looks like stock, so I'm getting some coilovers. As far as the ride quality, it rides great, just stiffer cause of the tires and RSB. I even kept the stock struts.
Former Sponsor
thanx for your help
thanx for your help
Konis and eibach, htech, or an aspec setup are all going to be pretty conservative. Also consider getting a rsb to prevent rubbing in corners.
What is the offset of the wheels?
Marcus
Here I come!
my bad, they're 225/40z/r18's
Marcus
Marcus
they are 18x8 with an 32mm offset and i have 245/40 Tire. Im looking for a even drop all around since i have a heavy trunk. and also something that not gonna ride harsh
emailnatec
29
09-28-2018 04:27 PM
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
us285126
10-02-2015 02:03 PM
4drviper
09-23-2015 07:42 PM
