Need Help Deciding Tires (19x8.5f & 19x9.5r +35)
I'm currently running a stretched setup at 215/35/19 & 235/35/19. The wheels are VarrStoen 2.2.2s. I know it's not too stretched but the ride is horrible (there are other factors as well) and I'm tired of dodging every pothole and manhole in NYC. I've already seen a few chips here and there and hitting a pothole really hurts. So my plan for next year is to throw on a new set of tires on along with powdercoating the wheels. I'm currently contemplating whether or not to go with 245/35/19 & 275/30/19, 245/35/19 & 275/35/19, or 245/40/19 & 275/35/19. I want the rim protection and a comfortable ride since I commute at least 60 miles daily but I also want something that will give my car a great stance. Can you guys post some 245/35/19 & 275/30/19, 245/35/19 & 275/35/19, or 245/40/19 & 275/35/19 on 8.5/9.5 setups?
Here are some pics of my car:
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8878.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8880.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8884.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8887.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8888.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8895.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8898.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8900.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8905.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8908.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8910.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8920.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8921.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8925.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8928.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8932.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8935.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8940.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8941.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8944.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8945.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8948.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8949.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8952.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8956.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8958.jpg)
![](http://img.photobucket.com/albums/v358/artluo100/IMG_8923.jpg)
well im tein basic coilovers. I'm maxxed out in the rear and about 1/4 inch left in the front from being maxxed out. Im running 19x8.5 +35 with 235/35/19 in the front and 19x9.5 +40 with 265/30/19 in the rear...My fenders are rolled..I dont rub at all and ride is not bad at all...Certain bumps you feel but thats normal for being so low
http://www.flickr.com/photos/83727240@N03/7854328198/http://www.flickr.com/photos/83727240@N03/7918347642/Ok..my opinion not knowing your offset on the front,and getting coils with a 2 1/2 inch drop. Roll your fenders and run 235/35/19 all around....with atleast 2 degrees of camber in rear....
Italiano, as you can see from my OP I'm trying to move away from a stretched setup. I'm already running 235/35/19 on the rear wheels (19x9.5 +35).
I'm looking at either 245/35/19 & 275/30/19, 245/35/19 & 275/35/19, or 245/40/19 & 275/35/19 to give the rims some protection and also drive comfortably. If anyone is running tires on their 19x8.5/9.5 wheels, please help me out
Im just considering that you are wanting to drop your car 2 1/2 inches like I am..that changes everything when it comes to tire size..sometimes different tires give you more lip protection then others even at the same size...once you drop it from looking at how your rear sits...I stick by my specs I gave you...215 in the front is def not nessasary...Im running more agressive specs then you with 225/35/19 all around...
Registered Member
And I would go with Italiano's tire size recommendation. 235 front 245 rear. I have 8.5 rims all the way around and have a 235 tires. It is very very minimal stretch and the ride quality is great.
2014 Jeep SRT
245's on a 8.5" wheel are way more than enough to avoid stretch. You could run a 235 on a 8.5" and not have any stretch. I'd go 245 front and 255 rear, or 245 all around. I can't imagine a 275 will fit on the back without rubbing unless you're only lower about 1".
http://i1211.photobucket.com/albums/cc424/bluetl04/car1.png
http://i1211.photobucket.com/albums/...untitled-1.png
Now this is an awesome stance:
![](http://farm4.static.flickr.com/3034/2710718704_42fb7813fc_o.jpg)
TLDude876
12-28-2016 03:18 PM
oyayjoe
09-12-2015 04:40 PM
