need advice on suspention parts
im ready to drop my 2005 TL base model. i want to get front and rear camber kits if needed. i am dropping it 1.5 inchs. i was looking around but only found ingals. i dont want ingals, because i had bad expierces with it on my integra. i also wanna know what companys makes lower tie car ( i perfer benen) and what compay makes lower control arms. if tl even have them or if they even make them. i dont know much about tl's but civics integras i know all types of companys makes them thanks
I know that fastline makes endlinks for the swaybar. Ingalls makes the camber kit like you stated. Some other members here can chime in on it.
I had the Wicked kit but it didn't fit the tapered end and its the top not the bottom control arm.
I never did find out if it was just mis packaged or what but it did look like a good quality kit.
I now have the Ingals ... what "bad" experience did you have with them .. thats the first I have heard of a bad experience with Ingals.
My rear kit performs well, installed super easy. Ingalls has high regard around here. Most 3G TL's just do the rear only at that drop amount.
Did you grease the contact points, and raise the susp to normal ride height before tightening anything down?
Search around. This has been discussed a whole lot, tons of info here.
Former Sponsor
Ingalls makes the best option for the rear since it has 2 arms per side to adjust camber and toe.
However, if you don't want Ingalls, SPC makes camber kits too:
http://store.excelerateperformance.c...5/i-68794.aspx
http://store.excelerateperformance.c...5/i-68797.aspx
You need two of each.
94 DC4 RS LSV/Turbo
I installed the wicked kit on my car and it was no trouble at all
benen is no longer in the business of making lower tie bars... they only make tow hooks now![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
fyi. if you want lower tie bars... look for those made for the tsx they fit
pm the above vendor he can source em for you
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Soul_Deamon
11-13-2018 04:44 PM
mike from annapolis
05-07-2017 08:21 PM
BobbyGraham388
10-22-2015 05:05 PM
