my day is ruined fml
so after 5 months of my car being in the body shop and 3 months of looking at my work vsxx so today i finally had time to get them on and they wont go on. i got 10mm spacers and it just clears the brembo (is that safe)...and now my problem is i can get the lug nuts to thread on so im wondering if i should get the bolt on spacer kit or run extended studs? my rears went on fine and i think im not gonna run a spacer on the rear because if i do the lugs wont thread on. anyways i know if i get extended studs i gotta get them pressed in but i also heard from a friend that if i get the bolt on spacer kit i would need to get that pressed on too as well? can anyone confirm that for me and let me know whats the best way for me to get my front wheels on. thanks
this was the spacer kit i planned on getting
http://cgi.ebay.com/ebaymotors/KICS-...Q5fAccessories
ScoobyZINE
anything about wheel spacers but I'll chime in..
Looks to me with the spacers in that link, your stock studs will have to be shortened. I figure if you have to remove the hub to have the studs shortened, why not go ahead and have new longer ones pressed in? That way there is no worry on the spacers failing. I've heard that a 5mm spacer is the most you want to run on our cars without extending studs etc, sounds to me like the offset of your wheels is wrong. There is a thread somewhere about the right offset to buy for wheels to clear the brembos.
I'll let others chime-in on this, hopefully I helped a little
Edit:https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/lowest-offset-widest-rim-width-08-type-s-781453/
Edit:https://acurazine.com/forums/showthread.php?t=781453
From a 2G to a 3G!
wait wait hold on, is the stud too long or too short?? if its too short your stucK! i JUST replaced my stud, look how short it is, you can "pull" this out..
u can definitely not "beat it and pull it out"
I don't use an air gun, just a 4-way and do it all by hand. I have replaced many broken or cross-threaded studs on various cars over the years with this method. The tricky part is trying to get the stud pulled all the way back through and being sure it is all the way through. I usually end up putting the rims back on, tighten the lugs, drive it around the block, check the lugs, and repeat a few times to make sure everything is good and tight.
yooo jmill im leaning towards the spacers with studs in them already because i dont want to run open end lugs during the winter time because my stockies can get jacked. but im wondering how that spacer will work? when the new 10mm spacer goes on over the stock studs will the but that holds it on cause any interference with the studs being too long...do you understand what im saying?
teaser pic
so once i bolt on the new spacer kit whatever from the factory studs is sticking out will go into the triangular holes in the back of the wheel?
also with the 10mm spacer there isnt that much room between the wheel and the caliper maybe i can stick a credit card or two in between there..so can bump the spacer up to 12mm for more clearance?
also i heard that the icihiba v2's are car specific because they have built in hubrings so where can i get this spacer kit?
Seems to me that if your 07 was actually being worked on for an entire month, the only way to say you "made out good" is if they bought you a new TL, because if it took that much work to get the car road worthy again, it probably should've been totaled.
teaser pic
I would go with a 12mm spacer then 1 or 2 CC clearance is close.
You have to find out what the center bore of the rim is and get one to fit that and that goes over the TL's hub which i think is 64.1mm if those rims came off of a TL then why dont they already fit? Looking at the picture of the back of your rim it looks like the yellow ring part in the hub center is the hubcentric ring for that rim... now when you get the spacers they make them now hubcentric... most rim manufacturers make rims with a larger hub hole and we just add the plastic hubcentric rings to fit the car we have that way rim makers done have to make a specific rim for each car... do a search on hubcentric spacers that is basically what you need
Longer studs> bolt on spacers any day of the week. Order a nice set from ARP and be done.
I have long studs that stick out 1" past the lug nut (a track requirement). If they're a little too long, there are tons of open ended lugnuts made for that. This is one area you don't want to screw up on.
well it only took two weeks for everything because the guy who worked on the car went on vacation for 2 weeks. i got a little over $20k for the accident and it only cost $8500 to fix the car so pocketing almost $12k in my mind is making out good i paid off half the car with that money. maybe you dont realize it but when the passenger air bag goes off you need to replace the whole dash. everything had to be taking apart and then put back together also the car needed a alignment and the a/c had to get recharge becuase they replaced the condenser. most ppl will agree with me that making almost $12 is making out good
yes the triangle part in the back of the rims is where the existing lugs will fit once you add a spacer.
94 DC4 RS LSV/Turbo
the only spacers I'd run
http://www.motorsport-tech.com/wheel_adapters.html
you should be able to get a 19mm spacer behind that wheel... and be golden
