Lugs for Axis Hiros?
2005 Acura TL w/ Navi
ok so i bought new shoes for the TL about 2 months ago (Axis Hiro's hyper silver 19's, 235/35/19) and realized how easy it is to strip the lugs that come with it, has anyone else had this problem? ive actually stripped 2 of them and it took me hrs to get them off and i actually damanged/scratched 1 of my rear rims trying to get the stripped lug off..anyone suggest new/different lugs to use on Axis Hiros? either black or chrome look? im nervous to take my wheels off unless i have new lugs to replace them with so i dont have to deal with the headaches of ruining brand new set of wheels
iScrape going into
just hand tightened..im not torqueing them crazy tight..the key that slips inside the lug to twist on and off the lugs eats away at the tiny metal slabs that grab on the inside of the lug little by little and it basically strips it, just a pain to get them off once there on so im trying to advoid removing them right now until i have new lugs. how hard is it to replace the wheel studs? never done it before - wouldnt even kno where to begin
If they take the tuner style lugs this is what I use and they been on and off prolly 20 or so times. The locking one is multi splined and has its own key if you decide you want to have one on each wheel.
![](http://img.photobucket.com/albums/v499/JessTzn/DSC01247.jpg)
94 DC4 RS LSV/Turbo
wheel studs? VERY EASY...
the rear is like out of a 1 to 10 difficutly I give it a -50
the front requires you to do a little skillfull ghetto rig... you can hammer all the front one's out but to get them in there is an annoying dust shield behind the hub which you can bend and hammer in the new studs
tool to make your life easier impact hammer
do you know if they would fit on the axis hiro's? where can i order them from? also ive noticed searching for lugs, theres different treading sizes? when i called up axis they told me any normal acorn lug would do..but whats the normal/regular thread for our cars?
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
do you know if they would fit on the axis hiro's? where can i order them from? also ive noticed searching for lugs, theres different treading sizes? when i called up axis they told me any normal acorn lug would do..but whats the normal/regular thread for our cars? ![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Here is a link explaining it
http://www.tirerack.com/wheels/tech/...sp?techid=102&
Here is the ones I got for mine and they are 12mm x 1.5 , I also ordered 4 locking ones of the same style.
http://cgi.ebay.com/ebaymotors/12X1-...mZ270287584022
Having the wheel supplier tell you "any" acorn nut will fit is pretty slack given they can be 3 different seat styles. And the size of the holes in the wheels can also dictate the type of lug needed.
To make sure take a lug off the wheel and look at the seat to see if its spherical or conical.
neuronbob
23
07-16-2019 10:48 AM
