Lowered and vibrating at highways speeds?
So i just lowered my car on form and function type 1 coilovers this week the first two days i had no problems with the ride at any speeds. This morning I changed the wheels and lowered the car just a bit 1/2in the front. The car rides fine at low speeds but slightly vibrates at 50mph or more does anyone have an idea what could be the cause?
takin care of Business in
Received 4,732 Likes
Have you had it aligned yet? Also might re-check the nuts and ensure they're torqued to proper spec, could've loosened up a bit ?
My car was a little slippery after lowering it, sort of got slippery if I went over a man-hole or the little white reflective dots inbetween lanes. I had it aligned and the problem is gone now.
Rattled a little too, its perfectly fine now though after having it aligned.
Is the vibration felt in the steering wheel or the seat?
If it didn't vibrate before putting the wheels on then its a wheel.. Just because it was balanced .. doesn't mean it was balanced right.
If you think its the nut ... change the nut to oem.
