Recommended Camber Kit?
Old Mar 9, 2012 | 10:17 AM
TrixR4Kidz's Avatar
Which camber kit do you guys recommend for a 3G TL? I dont know much about them so don't know where to look. Found some on ebay that come with just the rear for around 80-100 bucks, but I'd like the front as well. If anyone could give me some direction i'd appreciate it. Thanks!
Old Mar 9, 2012 | 12:34 PM
JD TL-S's Avatar
You might not need the kit. I lowered my TL about -1.7" from and rear using Tein SS coilovers and when I got an aliegnment they were not needed. I bought Ingalls best adjustable rods for the rear and the mechanic said he didnt have to adjust them at all. I had then set to the same length as the OEM non-adjustable rods.
Old Mar 9, 2012 | 01:32 PM
TL Seth's Avatar
if you are going 3 inches down, you need a camber kit for the front and back?
Get the ingalls all around instead of skunk 2 ingall combo which is more expensive?
Sorry I have many questions, few answers lol
Old Mar 9, 2012 | 02:28 PM
JD TL-S's Avatar
Like Seth said.
It all depends on HOW-LO-U-GO
Old Mar 9, 2012 | 02:42 PM
TrixR4Kidz's Avatar
Well I'm going to just lower it in springs for now so maybe an inch in a half. I just like the way the rear wheels look cambered which is why I'm considering a kit
Old Mar 9, 2012 | 07:21 PM
Slpr04UA6's Avatar
-------Tim-------
Lowering it alone will give you negative camber, if you would like more than a kit will suffice, or if you would like to correct excessive camber the kit can do that. Some members lower first, then allign making sure toe is close to if not 0, then determine if they need/want a camber kit. Check out our vendors here on Azine, like Excelerate/Heeltoeauto. What springs do you plan to lower it with?
Old Mar 12, 2012 | 07:45 PM
Excelerate's Avatar
Former Sponsor
INGALLS makes the best rear camber kit. It includes 2 arms: one for camber and one for toe. You need a qty of 2.
http://store.excelerateperformance.c...5/i-60220.aspx
Old Mar 12, 2012 | 09:16 PM
TheDingo's Avatar
Resident Dingo
^ i agree
Old Mar 26, 2012 | 10:59 AM
xmrgoodcatx's Avatar
Pham Alvan
May 18, 2021 06:48 AM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
urbtsx
Sep 27, 2015 09:40 AM
0opie
Sep 22, 2015 04:15 PM
