Looking to replace rotors. Suggestions?
Hey guys i got a 2008 tl type s. so far so good but I can't stand the vibration while braking. Specially at high speeds.
Some people have told me to get the rotors machined and some people say that these can be machined but its best to replace as machining them will warp again anyway.
Looking for a replacement but not sure exactly where to look. Obviously I want good quality but refuse to pay stealership fees. Don't mind waiting for shipping. Any ideas would be great or if you guys can give your input in machining that would be great too
Are you sure its your rotors? If you're breaking at high speeds and you're getting vibrations you might need to get your wheels balanced. If it is your rotors you can try cutting them and re-using, but if they've already been cut, then you should get new ones. check out https://acurazine.com/forums/3g-tl-2004-2008-93/adam-here-adams-rotors-873922/ for new rotors
Stay Out Of the Left Lane
Received 1,237 Likes
How many miles on the rotors? Have you owned since new?
Two schools of thought -
You can definitely get the rotors turned, but at some point they will need to be replaced. The "some point" could be tens of thousands of miles down the road. Honda/Acura rotors are known to warp and some will tell you thinner ones will warp again faster.
Option two is a straight replace, but may be a little more costly. Theoretically you are starting from scratch.
So again some of this may depend on you and your brakes and how many miles you have rolled up on them.
I've actually done both and had success both ways.
Are you sure its your rotors? If you're breaking at high speeds and you're getting vibrations you might need to get your wheels balanced. If it is your rotors you can try cutting them and re-using, but if they've already been cut, then you should get new ones. check out https://acurazine.com/forums/showthread.php?t=873922 for new rotors
The fact that he only feels vibrations while he uses his brakes pretty much throws wheel balance issue out of the equation.
Received 3,824 Likes
Absolutely loving these
http://hoa.excelerateperformance.com...s/g-71488.aspx
I had Brakemotive once too but I ended up with too many vibrations. Plus I wanted to get rid of the drilled holes. The XLR8 kit I have is slotted only.
Slots>holes
I like turtles
Holes look good but go only slotted or blank. Stoptech is a great brand, I'm using their brake pads and I love them.
Another rotors option is adamsrotors they have a thread on here.
When I took my car is for a brake job, they highly recommended not machining the front brembo blanks due to possible warping. It's not that much to replace them
I have StopTech slotted rotors that I'm waiting to install. The stock rotors/pads are still going strong with 60k miles on them. I'll replace the rotors/pads in a few months or whenever I hear the wear indicators.
I wouldn't mess around turning rotors- you're almost guaranteed to warp turned rotors.
I was just looking at replacing the pads from my brakemotive kit. I've had them on for maybe 12-15k miles, and they need to be changed.
I've been having some wild vibrations when stopping at highway speeds, and they have just generally been quite loud all around. I think I'm just going to go with the stoptech slotted only kit with the pads.
I loved the price of the brakemotives.
Well I've recently just purchased the Car so no idea if they've been turned before or not.
Car currently has 83k km. but yes doesn't matter if I replace them. Just looking for alternatives and advice wether to turn them or not
Former Sponsor
I'd recommend taking a look at our Acurazine XLR8 STOPTECH brake packages.
saberlove
03-11-2021 09:29 AM
Joseph Stansbury
34
12-04-2015 01:57 PM
