Looking into Eibach springs
Hey guys, I have an opportunity to get eibach springs at a really good price. I know many of you suggest coilovers, but I'm not looking for anything that serious. Ideally I'd like A-spec suspension, but this is much more cost effective right now.
I'm only looking for a slightly sportier ride, with a minimal drop. Would I need a camber kit with the eibach kit?
What are your opinions?
Former Sponsor
That kit will only lower you down about an inch. Assuming you don't have any suspension components that need replacing, you shouldn't need a camber kit as you will most likely be within spec.
Eibach Pro Kit Springs - Excelerate Performance - Japanese and European Performance Specialists!!
CB900Fer (05-08-2015)
Eibach Prokit lowers 1.5" to 1.7" after settling, speaking from me who ran them for 7 years with Koni yellow adjustable shocks. H&R OE Sport is the one that lowers 1" after settling.
You WILL need a rear camber kit because you'll go over -2 degree of camber in the rear. Get SPC, not Ingalls.
The following 2 users liked this post by t-rd:
Well, I picked them up and they're basically brand new. I'll install them with my OEM shocks and then have the alignment checked out of curiosity (they typically check for free here).
Thanks guys
Thanks guys
You are wasting money if you aren't pairing them with performance shocks. You will always wear out the stock shocks faster because Eibach Prokit has way higher spring rate than stock springs.
Former Sponsor
Definitely should pair these springs with a shock like the Koni Yellow.
Koni Shock - Sport Series - Excelerate - HOA - Japanese Performance Specialist
I'm about to pull the trigger on these springs and I've been set on yellows since the beginning.
thanks
I drove on the Eibach Prokit + Koni yellow adjustable shocks for 7 years on my old 98 Accord. I can probably find pictures but it's been 10 years. The ride quality is decent with the front shocks on 1 full turn and the rear shocks on 3/4 of a turn. It is stiff, but it isn't intolerable. Cornering is way better. I now have a 07 Accord V6 on HFP suspension and the HFP is soft compared to the Eibach/Koni setup.
AmplifiedDetails (05-12-2015)
Hey guys, thanks for the input. I've actually decided that I'd rather only do the necessary work (and alignments) once. With that in mind I'm saving up for an A-spec suspension setup.
Here are my Eibach springs in the Black Market: https://acurazine.com/forums/car-par...prings-930886/
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
