KONIG ZERO IN , your thoughts
everybody whats up,
my girl wife took my baby for a drive yesterday and sure enough i got a call later that afternoone from her saying she cracked one of the rims![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
anyhow, im looking to get new ones and really liking the konig zero ins. Let me know what you think:
iam in NY roads are shit im tginking on staying with 17'
the stock wheels are 17x8 and the Konigs are 17x7 will i be able to use the same tires?
will the width downgrade have any major effect on driving?
![](http://www.flickr.com/photos/53333554@N08/5032265852/)
no way man never go smaller on width! if your staying 17 you gota do at least 8 if not 8.5 or 9 get some meat on those tires then... if u go 7 inch wide your shit will look hilarious tires will be all buldged even just running a 235 width
i figured... can i strech my tires to 18x8 rim?
nope u can't stretch the diameter of tires, only the widths ... and its not really stretching the tire persae its just making the sidewall angle out more to fit the width of a wider rim.
so if u had a 235 width tire on a 7" wide rim it would look all buldged at the sidewalls; on a 8" wide rim it would look like the sidewalls are straight up from the rim like stock; and on a 9" wide rim then the sidewalls would be angled in making it looked stretched to fit the wider rim
u can make various sized width tires fit different width rims but only to a point then the bead will not hold and fail.
if u wana change rims only id say stick with stock or try to find some type s rims... if u wana go 18" u can find some A-specs or something else but do not go smaller than 8" wide
http://www.flickr.com/photos/53333554@N08/5032637373/
Hey bro thanks for all the info that def helps! so the zero ins are out of picture what about something like that? they are 17x8.5
just make sure the bolt pattern is 5x114.3 and the center bore of the rim is at least 64.1mm (if its larger than 64.1mm you can use a hubcentric piece to make it fit snug) and make sure the offset is at least +40
yea those would work what is the offset? you planning on switching your existing tires from your old rims to the new rims is that why you want to stay with 17" rims??
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
how are original 17" alloy wheels rated? ar they good
ok just ordered lets see how it works out, hopefully this is how it will look
http://www.flickr.com/photos/53333554@N08/5033964355/
http://www.flickr.com/photos/5333355...n/photostream/
Those are dope. I'm looking forward to seeing them on your ride.
What size tires are you running? They look super beefy.
Fearless DIY Guy
I too am on the fence with the 17 vs 18 battle as I drive well over 20k per year and would rather have a sublime ride if some aesthetics need be sacrificed.
Ya got me thinking now, dammit...
What was the size + offset? You have brembos in the front, correct?
the offset on this is 17x8x28 offset. fronts are fine rear rubs a bit but only under biger pressure( turns or heavy load in the back) all breaks are stock acura oem
I know most people upgrade to larger size and it does look fking great but i really dont wanna kill the ride just for looks.
Fearless DIY Guy
Well, after a bit more research, looks like you and I will be rocking the same rims (until I send them off for a pc job, haha)
Thanks for posting the pics and the info on here, looks great.
