Koni SP3 install
Old Aug 2, 2013 | 03:33 AM
paperboy42190's Avatar
Koni SP3 install
Got some questions regarding the installation of the koni yellow sp3 shocks. I drilled my type s top hat bushing without a problem, but what did you guys do about the silver collar inside the bushings? There's no way to drill through that with conventional methods, so I pried it apart enough to fit the shock, then it became too wide to fit back into the bushing. So for now I installed everything back without the collar as I did not feel it's a necessary part of the suspension.
How did you guys do it?
Old Aug 2, 2013 | 07:02 AM
it is necessary!
the collar fits inside the bushing in the top hat.
with that being said; my konis came with additional wider collars
Bushing
collar
bushing
Old Aug 4, 2013 | 04:00 AM
unfortunately mine didnt come with the wider collars....but my car has been driving perfectly fine so far. I would guess the collar might take away any "play" inside the bushings but with type S stiff bushings, the collar shouldnt make much difference right?
Old Aug 4, 2013 | 04:27 AM
in any case I'll try to contact koni for replacements
Old Aug 4, 2013 | 08:34 AM
so, you dont have the collar but have the bushings installed? they just fit into the top hat?
Old Aug 4, 2013 | 03:11 PM
yoks032rs's Avatar
since you have everything bolted back up, I would just leave it alone and see what
happens. But if it bothers you enough with out the collar...well you know what your
going to have to do?.. Take it all apart. If it was me I would just hang with it.
Old Aug 8, 2013 | 11:13 PM
I can remove the top bushing without taking off the suspension. that gives me enough room to put the new sleeve in. however im still trying to figure out how to fit a new one in. koni doesnt have more for sale, and Im just trying hardware stores looking for a steel tube of the same diameter but no luck yet.
I looked up the part numbers for type S and base tl bushing, and its the same. so how do base TL's fit the top hat? People say its plug and play but that is NOT possible. someone please help?
Old Aug 8, 2013 | 11:14 PM
yes exactly, they fit and ride just fine but for longevity of the bushings I'd like to find a steel collar that fits
Old Aug 8, 2013 | 11:20 PM
JJH's Avatar
JJH
My Konis came with a steel sleeve that was the correct diameter. I simply pulled apart my type-s bushings, removed the stock metal sleeve, drilled my type-s bushings, and then put it back together with the Koni sleeves. I also had to drill the dust boot. Everything else was plug and play.
Old Aug 9, 2013 | 12:04 AM
^yeah thats how it should go. im just getting frustrated I cant fit these, since everyone else is saying "o its plug and play" and im just thinking BS!!
look at this thread, people say thats its plug and play: https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/help-koni-yellow-type-s-bushings-837206/
Old Aug 9, 2013 | 02:47 AM
i ordered a steel tube of 12mm ID, 1.5mm wall, and 15mm OD. matches up pretty well with the stock one I measured. I'll post back soon. mcmaster carr's warehouse is located near my house so i'll do will call pickup
Old Aug 10, 2013 | 03:10 AM
I was really glad I am able to access everything through the top and did not need to remove the suspension again
Old Aug 10, 2013 | 10:05 AM
JJH's Avatar
JJH
Nice!
Old Aug 10, 2013 | 11:39 AM
yoks032rs's Avatar
Looks good. Nice to know you just had to remove the top hat.
cycdaniel
Dec 17, 2019 10:58 AM
jblessing
Aug 8, 2018 09:43 PM
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
CLsuperhero
Sep 23, 2015 12:53 PM
TxRzrBk
Sep 17, 2015 01:07 PM
