KONI SP3 help!
KONI SP3 help!
The dampening adjusting tab on the top of my rear struts won't budge.
They seem to be depressed all the way down too.
Heres a picture:
I contacted Koni this morning and they said that this can happen if an impact gun was used for the top bolts. His suggestion was to compress the spring again and see if the tab pops up. If it doesn't, he recommended I go thru Koni warranty to have them fixed/replaced.
I didn't check them when I bought them to make sure this damage wasn't there already (bought them used)... dammit.
Anyone here have any suggestions?
Also, the struts are double nutted on the top... if I only have 1 nut on a strut, will that nut loosen? I can't find the second nut...
Heres a picture:
Yeah some of those bolts are a pain in the ass to access. I'm riding without my rear seats at the moment.... which is convenient as I just reconditioned the leather in my living room! Sweet.
"Like None Other"
hmmm....not really sure about the rear yo....do you think they are just stuck like "pressed down"?? maybe u can pull up slightly on the adjuster knob. couldve just got jammed from being handled around. just seems bizarre that they woiuld be stuck and wont turn either way....vice-grips and a hammer using a soft touch??
