Koni settings and comments
Old Aug 14, 2012 | 11:29 AM
  #41
beyond 1000's Avatar
A few more questions here.
1. At the softest setting does it duplicate stock, is is softer than stock, or firmer than stock?
2. Regarding adjustability...Fatfri you mentioned getting the interior all back in. Is it difficult to adjust on the fly? What do I have to constantly remove to get at the adjustment knob.
Thanks again
Old Aug 14, 2012 | 05:26 PM
  #42
Fatfrii's Avatar
i have upgraded both my front and back sway bars so they are way stiffer. this means that when i put it on all the way soft it puts too much stress on the sway bars. this causes the car to wobble coming out of a turn. If you have stock sway bars all the way soft might be ok.
you have to take the back seats out and also the rear shelf to adjust the back. you can not do it on the fly. for the front you have to take out the strut brace. the adjustment is made on the top of the shock.
you have to be seatless for a while in the back until you have tested and got a setting you like. make sure u test both street and highway for stability and handling
please do not post any more unless it is about firmness settings or comments about them. feel free to PM any questions
Old Aug 14, 2012 | 05:53 PM
  #43
i went from '06 6mt suspension to koni yellow+aspec spring setup.
I have just recently tightened up both front and rear.
the fun didnt start until I stiffened them.
meaning, it did feel quite stock-ish with them on soft.
Old Aug 15, 2012 | 05:32 PM
  #44
Fatfrii's Avatar
its about time man uv been talking about tuning ur shocks for ever now! u keeping track of ur settings or just messing with um till u like it?
Old Aug 16, 2012 | 03:15 PM
  #45
DC2many's Avatar
Does anyone know if koni have transferable warranty?
My driver side is leaking and the set has 7k when i bought it (according to owner) they looked minty though
I've driven about 15k with them so they should still be at the beginning of their life span. Although they were made for the accord so the rebound and rates may not be proper for the TL
Either way, would I have down time if i were to take the shock off and replace send it in if Koni even allows it? this is frustrating... Or can I roll on these till they all leak and change it
Old Aug 16, 2012 | 03:48 PM
  #46
Lazer187's Avatar
Koni Softest setting is equivalent MAYBE just slightly stiffer than the Stock Type S Suspension
Old Aug 18, 2012 | 08:32 AM
  #47
pinina's Avatar
I have my koni's yellows paired with some H&R Race springs.
Springs are on the lowest perch.
Fronts are 2 full turns.
Rears are 1/2 turn.
Ride kicks ass!
Old Aug 21, 2012 | 01:28 AM
  #48
Fatfrii's Avatar
^damn u got ur fronts on pretty damn stiff hows the comfort? i bet you glide going over 100 though
Old Sep 2, 2012 | 11:51 PM
  #49
pinina's Avatar
I love it.
So much better then when I had the Aspec setup.
Marcelechka
Home & Garden
188
Sep 11, 2022 11:53 AM
gatrhumpy
19
Dec 31, 2015 04:22 PM
RobbDizzle
Oct 15, 2015 11:16 AM
eastsideride
Oct 15, 2015 04:26 AM
0opie
Sep 22, 2015 04:15 PM
