interchangeability question
Hi guys, do any of you know if a 7th gen (2003-07) v6 Honda accord suspension would be interchangeable with my 08 TL Type S?
(I've tried searching, but only found 4cyl accord to tsx info...
thanks
thanks
I need a new suspension for my tl-s as the fronts are blown (literally riding on springs) and I've just recently put new (stock) struts with tein stechs in the accord (which I won't be driving regularly anymore, i'll probably use it as a winter beater). otherwise i'll have to buy a new suspension for the tl...
i wouldn't do it. if the car weights are different and their handling characteristics are different (most likely both), you will be underdamped and bouncing all over the place, and will ruin your "new" suspension quicker
but that's just my two cents, your call!
They'll fit. The '06 Accord is only @ 150 lbs less than the TL, shouldn't made much of a difference and will be a cost savings.
Doesn't take long to change, so give it a try and see if the handling is up to your expectations.
