Installed Springs, some questions
A6 and TL
Hi,
I paid a member to install my Neuspeed Sport Springs yesterday. I like the look, but I have some questions. I have a 2 finger gap up front and barely a 1 finger gap in the rear....but my rear tires as of right now are 225/55/17...I think when I get the proper tires I will have 1 finger gap.
Anyways, I noticed my front right side is a little lower then my front left side. Not by much its like a 1.0-1.5 CM difference. Is this something to be alarmed about? Can is handling better. You can't even really tell.
My rears are perfect but when going over a bump or a dip in the road at lets say 45-60 mph the right rear makes a clunking noise. This does not happen all the time. Going under 10 mph it never happens unless you hit the bump at an angle...you hear it but other then that nothing at low speeds.
Thank you in advance!
Have you gotten an alignment?
Hi,
A6 and TL
The gaping is made that way to compensate for the engine weight. And the gap difference from the left and right, dunno. That clunking noise you hear in the right rear is your strut mount. Needs to be replaced and should dole check all the nuts and bolts after couple days of driving. I had my fair share with suspension on my late 94 legend gs so I know. Alignment has nothing to do with the clunking or gaping.
Also a quick question...why would a strut mount go bad? It was not making the noise before and happened right after we installed the springs. In any case my car just hit 30k today so it should not be the strut mount. I heard sometimes the springs "clang" together so you should put a "covering" to prevent the noise. What even is a strut mount?
Anyways it does not happen on every bump. I live in NY and we have bumps everywhere. It happens only when I go over a bump at a certain angle. If I am going very slow it seldom happens. Worst case, I live with it.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
^^^strut mount is pretty much a metal plate with a rubber bushing to hold the spring in place to the strut or some people call it "top hats" if I'm not mistaken. I should know this since I worked in the industry for almost 5yrs and messed around with my old car a lot. Once you taken it apart it's not a guarantee it'll be the same. Dunno about the spring "clanging". Its not the struts since they should be good for 50k or longer. Would have to hear the noise to determine exactly for sure but I'm certain it's the mount. I have 35k on my car and I know for sure the mounts are bad in the rear. Only on certain bumps I hear the clunk noise from either rear. Our streets here in Philly aren't any better than your in NY.
A6 and TL
My friend has a IS350 and he has F sport springs they are OEM like Aspec springs and they all clunk over bumps, my right rear only clunks.
A6 and TL
And it happens on some bumps only. I would think its a big issue if it was happening at every bump/dip. I should just go slower over bumps anyways now that I am lowered
cycdaniel
12-17-2019 10:58 AM
Skirmich
09-15-2015 06:41 PM
