Instability when passing over a bump
I have a 2005 with 137k, and when passing through a bump over 45 mph feels instability in the rear.
It's feels like if the rear section slip to the side where the bump was.
Bad shocks?
Bad alignment?
Bad shocks?
Bad alignment?
Wasn't there a TSB for this?
Edit: NVM, that was the bump stop TSB for premature tire wear.
But yeah, OP, get your alignment checked. Do you have any load in the back seat and/or trunk?
No, just kids seat in the back seat and the trunk is empty. Someone tells me that could be something is broken, exactly Broken sway bar end links, but this "feeling just happend when the car reaches a certain speed.
what would be the recommended alignment for acura tl 2005?
Registered but harmless
Received 1,149 Likes
The toe should be set to "0," or as close as possible to it, on each of the four wheels. Caster and camber are not conventionally adjustable.
This applies to all 3G TL models with stock suspensions and wheels (including A-Spec).
The tire shop/alignment place should have the specs too.
emegge23 (02-27-2015)
The struts are probably nearing the end of their useful life. If you don't see anything obviously broken, check your tires. What kind are they? Are they inflated properly? Are they showing signs of uneven wear?
I put new snow tires onto worn struts that gave me similar problems. Just put new Koni Yellows on and now everything is good.
BTW, to replace this rear struts is necessary remove back seats?
emegge23 (03-02-2015)
If you haven't checked the alignment, you def. should first. After that, look into new shocks to replace the worn ones. You'll need to do an alignment after you put the new shocks in and the car settles.
I really doubt the issue is due to the rear shocks, but it doesn't hurt to them for leaks. But definitely get the alignment checked. I'm going to bet that camber and toe are out of spec on at least one side, if not both.
MrHeeltoe
20
02-23-2023 01:54 PM
emailnatec
29
09-28-2018 04:27 PM
kb1rl
09-30-2015 10:17 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
