I'm Confused...Somebody help me figure this out..
Since changing the tires/wheels to CL-S wheels and 225/45/17 rubber, I knew that the speedo would be off....but by how much was my question.... So the other day I was driving, thought I would time 1 mile and how long it would take... Cruise control on at 60mph on the nose.. Turned on my stopwatch as the 1/10th meter changed, and timed how long it would take to go 10/10th, or 1 mile. The time came out to 70 seconds it took to go 1 mile at 60 mph...Can somebody figure out how fast I was really going? How far off is my speedo at 60mph?
Ed
Ed
I think you are actually going at 51.43 MPH.
1mile | 60sec | 60min
-------------------------------- = 51.43
70sec | 1min | 1hr
your overall circumference is 199.27 cm (225/45/17) compared to stock 204.96 cm (205/60/16).
70sec | 1min | 1hr
<b>EDIT- This post is incorrect - read correction below!</b>
but then i suppose wind resistance, rolling resistance, grade of the road etc could have an effect.. as well as human error (no offense but u know )
in any case.. to find out the difference, just find out the diameter difference between the stock wheels and these wheels
205/60/16
16"=406mm
60% of 205mm is 123mm
overall diameter=529mm
225/45/17
17"=432mm
45% of 225mm is 102mm
overall diameter=534mm
that makes up for a diameter difference of only 5mm (about 1/5")
overall circumference is Pi*D so
stock circ = 1661mm = 1.66 meters = 5.45 feet
new circ = 1677mm = 1.67 meters = 5.5 feet
this means that for every revolution of the wheel, with the new wheels you'll go about a centimeter and a half further (figure half an inch)
so if i didnt make some horrible mistake above, if your speedo is showing 60, you should actually be going slightly faster than 60
lets see........ a mile is 5280 ft
on the old wheels, to go a mile, you'd need 968.8 revolutions
with the new wheels, you'd need 960 revolutions
if your speedo is configured to your old wheels, that means that 968.8 revolutions per minute = 60mph
with the new wheels, you'll actually cover 5328.4 feet which is 1.01 miles. 1.01 miles per minute= 60.5 mph
so there u have it (of course i welcome everyone to check my math please )
205/60/16
16"=406mm
225/45/17
17"=432mm
ed, from your info, you went one whole mile in exactly 70 seconds. so basically, distance/time = speed. based on the formula, you are going 51.43 MPH according to your info. but if you're going 58 MPH according to Nate, I am pretty sure there's some human errors on timing and etc.
<b>CORRECTION! </b> as pointed out by red hot .. there are 2 sidewalls (duh).. hehhe oops therefore:
205/60/16
16"=406mm
overall diameter=652mm
225/45/17
17"=432mm
overall diameter=636mm
that makes up for a diameter difference of 16mm (about 5/8")
stock circ = 2047=2.04 meters = 6.71 feet
new circ = 1997=1.99 meters = 6.55 feet
this means that for every revolution of the wheel, with the new wheels you'll go about 5m further (figure 2 inche)
on the old wheels, to go a mile, you'd need 787 revolutions
with the new wheels, you'd need 806 revolutions
if your speedo is configured to your old wheels, that means that 787 revolutions per minute = 60mph
with the new wheels, you'll actually cover 5155 feet which is 0.97 miles. 0.97 miles per minute=~ 58.6mph
205/60/16
16"=406mm
225/45/17
17"=432mm
Original Member #81
But when the tires wear down...............
Here's the real formula!
Section width (x) aspect ratio (x) 2 (/) 25.4 (+) wheel diameter
Therefore:
Diameter
205/60/16 = 25.685039"
225/45/17 = 24.972441"
3% decrease
Therefore:
Circumference
205/60/16 = 80.65" - 982.02 rev/mi
225/45/17 = 78.41" - 1010.08 rev/mi
3% increase
3% higher speedometer meaning 60mph actually is 61.8mph
Therefore:
Diameter
3% decrease
Therefore:
Circumference
3% increase
Well, I was on this stretch of road for about 20 miles, and for about 10 of it I kept timing over and over and over... Each 10th took 7 seconds, I kept recounting it...
Ed
Ed
Originally posted by MikeS
Yes, you can have your speedo recalibrated....
Ed
Fool
03-10-2016 08:42 PM
