I need help rim question??????????
Will 19x8 +40 offset AXIS Se7ens fit I just got a great price on them rigt now $1300 with tires with little wear on them they are used they were previously on a prelude the tires are 225/35/19
also do you think they will look good my car is silver and so are the rims
I hope this goes through
let's put it this way...most people now that have 7.5" wide rims with a 42 offset rub slightly with 225 tires. now if you get wider rims (8") with a lower offset (40)... you see what i am getting at right?
are you sure they are a 40 offset? i believe a fellow tl member has the same size wheels but he has a 45 offset. can anyone confirm this? the guy has a 2002 abp tl-s.
Guest
Posts: n/a
Having no clue on the offsets to your car Im not sure about fit but judging from the previous replies it doesnt look good.However if they were able to fit IMO they would look good silver,on your silver car.Also $1300 with tires is a good deal.As for the quality its not bad.Axis also makes a 3 piece version of the se7ens which are quite expensive.Good looking wheel in any case.If they dont fit also check out Dazz Matis as they are nearly identical.
