i need advices on spacer. thanks...
i'm planning to get a set of sevas s22 for my 2005 tl 6mt (20x8.5f and 20x10r).In order to get around with bbk i have to install a 5mm spacer for the front only.
any experienced or commons please let me know. thanks...
buy eibach pro spacers...they come in a 64mm center bore with a 64mm hub on the spacer itself so even though you're using a spacer, your spacer is a HUB CENTRIC spacer, so when you put on your wheels, make sure you get some hub centric rings and it will be a perfect match. some places say don't use spacers cuz it's dangerous, as long as you don't get crazy with like a 20mm spacer...if you use a spacer that big, just make sure you have extended studs and use open end lug nuts so that you'll get a secure fit. spacers if used correctly can actually improve the performance and handling of your car.
yeah... i'm gonna use 5mm spacer. i hope is gonna work. according to one of the member, he said it will works , cuz he has 20x8.5 with 35mm front on his car.
any more suggestion... will be a great help. thank you all...
i have a friend that uses 45mm spacers on his race car....RACE CAR! there's nothing wrong with spacers...as long as everything is tightened, you should be okay...now this doesn't take into account that you may see more wear on your wheel bearings or what not....
soupi
14
11-15-2015 11:15 AM
