^^^please keep in mind there are a number of variables that will change what the CtC spacing actually means in ride height. A Type-S with an Auto (aka Heavy) and a Base with a manual (aka less heavy) will ride at different heights with the same CtC
COILOVER TYPE: Type II (V1)
FRONT CtC Spacing - 4-5/8" Wheel Gap - 1 finger gap Damper Clicks - 20 from the LO side REAR CtC Spacing - 4.5" Wheel Gap - Little Less Than 1 Finger Damper Clicks - 10 from the LO side RIDE QUALITY- Front feels really good and comfortable for daily driving. May adjust to 25 for some better handling. The Rear are a little too firm for me at 10. Lower back is kind of killing me. May drop to 5 or Full Soft. https://acurazine.com/forums/picture...ictureid=47467 |
How low can these coils go?? like can i be super dumpt on these?
pretty sure you can be to the ground lol
yes, you can ride on the floor with them...and megans etc...
COILOVER TYPE: I, Version 2
FRONT CtC Spacing - N/A - have to check Wheel Gap - just on top of tire REAR CtC Spacing - N/A - have to check Wheel Gap - a bit over rear tire RIDE QUALITY - the way I wanted it. firm without being very bouncy. Marcus did the install and he actually has the notes as to what my setup was measured at. absorbs the bumps real good and doesnt transmit the impacts into the cabin. |
(Post 13286006)
I'm getting ready to get the HT-Spec v2 Type 1 on my TL-S and need some clarification please. If you look at the following link from Marcus' write up about coilover adjustments:
http://heeltoeauto.com/files/tech/HT...ment%20Doc.pdf Would the collar to collar be the "Lower Bracket Height" as noted on page 4 of the document? Gonna get started on the install tommorrow or sometime this weekend and any comment/help would be much appreciated. Hopefully it doesn't take me the whole weekend since I have a J-Pipe to install also! Thanks! |
Are most of you guys running the "Standard Asian Suppply" spring grade or the "Eibach ERS Coils".
Originally Posted by faceman1
(Post 13244343)
FRONT CtC Spacing - 4-5/8" Wheel Gap - 1 finger gap Damper Clicks - 20 from the LO side REAR CtC Spacing - 4.5" Wheel Gap - Little Less Than 1 Finger Damper Clicks - 10 from the LO side RIDE QUALITY- Front feels really good and comfortable for daily driving. May adjust to 25 for some better handling. The Rear are a little too firm for me at 10. Lower back is kind of killing me. May drop to 5 or Full Soft. https://acurazine.com/forums/picture...ictureid=47467 Thanks :) |
Originally Posted by Skunkworks
(Post 13426022)
$899 with top hats installed is a great price, but $200 MORE for a coil upgrade is VERY STEEP IMO. Should be $100 IMO. |
Originally Posted by DeathMetal
(Post 13056021)
Just as FYI: The Type IIs get HELLA smoother after the first few weeks!!!
I think that's probably normal.
900 bucks PLUS another 200 to pick a different spring?!?! Why not just go for the Teins at that point? I guess you all wanna be able to put her on the ground... :) |
COILOVER TYPE II (V2)
FRONT CtC Spacing - 4" Wheel Gap - no gap, tires half tucked Damper Clicks - did not adjust yet (whatever they came set to) REAR CtC Spacing - 4" Wheel Gap - no gap, tires half tucked Damper Clicks - did not adjust yet (whatever they came set to) it defintiely needs to be set firmer, idk if they were in the middle when i put them on, or if they were all the way low... and there is a breakin period for sure... the difference in one day was very noticable... http://i1176.photobucket.com/albums/...s/IMG_8993.jpg http://i1176.photobucket.com/albums/...s/IMG_7857.jpg |
Originally Posted by JD TL-S
(Post 13427010)
Thanks :) Car looks sweet :) What wheels are those may I ask ?
Thanks :) |
jerzydevil609 .. looking good! :thumbsup:Let us know where you end up with the settings for front & rear for the V2's.
preciate that faceman!! question for everyone... did everybody just twist em to all the way soft and then start counting clicks? like i said before, i didnt mess with the dampening when i installed it, and its pretty soft now... i went and looked at the backs real quick (seat is still off) and it twisted both ways which makes me think it might be in the middle somewhere...idk... i'll mess with it today when i get off and report back...
also, my 4 inches was from the bottom of the spring holder rings where we all measured from to the red cup twisty thing, not to the ring sitting on top of it where everybody else measured to, so mines really 4 inches minus the thickness of the ring just to clear it up... not a big difference, but hopefully that wasnt too confusing.. |
... question...
for the front coils, (v2 type 2) i'm tryina adjust the dampening, but the knob and the lil gold piece with a bunch of holes its connected to aare both loose and dont click... i can spin them independently as well... am i supposed to tighten the gold piece with the holes independently of the red wheel and then adjust the red wheel? or keep em both loose, twist the red knob all the way lose then start counting clicks then tighten it down with the gold thing? it doesnt seem to click or when the gold part is tightened... idk if that made any sense at all but hopefully somebody can help me out... also put a email out to marcus at HT, but figured id share this in case somebody else was confused... the backs seemed to twist just fine, but i didnt really mess with those yet... thanks everyone for the heads up!! |
Yeah. Tighten the gold piece with the holes with a pliers. Just make it snug. Don't over tighten. If you get no clicks or it just spins after doing that your knob may be bad.
I never got a "positive" click when turning mine towards the Hi or firm side but could feel the clicks when making the damper softer. |
thanks faceman!!! i appreciate the help!!
I took the recommended settings from Heeltoe and went a little lower. I haven't adjusted it. Just installed it and loved the height it's at.
COILOVER TYPE: Type 1 FRONT Preload - 8" CtC Spacing - 3 3/4" Wheel Gap - 1 finger Damper Clicks - N/A REAR Preload - 8 3/4" CtC Spacing - 4 1/2" Wheel Gap - 1 finger Damper Clicks - N/A Ride Quality - Firm on decent streets. Pretty harsh going over bumps. Uncomfortable at times but it's a good solid feel imo. Passengers probably won't like it. http://i16.photobucket.com/albums/b4...h_P1030543.jpghttp://i16.photobucket.com/albums/b4...h_P1030544.jpg http://i16.photobucket.com/albums/b4...6/P1030542.jpg |
You just need aspec... :)
(Post 13499824)
Originally Posted by SpiderX1016
(Post 13499612)
Ride Quality - Firm on decent streets. Pretty harsh going over bumps.. |
1/2 of more preload is going to soften things up a bit? Sounds counter intuitive...
Check ebay for Ronjons...they are going for pretty cheap! |
(Post 13531196)
Originally Posted by jayunsplanet
(Post 13531199)
Indeed it does. But that is what I was told an hour ago on the phone by Marcus. He said I was thinking about it backwards.
(Post 13531124)
Marcus revised those settings. Preload should be 7.5 inches not 8. Out of the box they are 8in. I too noticed the ridiculous banging when hitting any average size bump. Shock is bottoming out. Marcus said making that 1/2in preload adjust will significantly help. I'm in the garage adjusting that now. :2cents:
(Post 13531196)
(Post 13531124)
Originally Posted by Mondo375
(Post 13545766)
7.5inches for just the front or all 4? If just the front then do the rears stay at 8 3/4?
Sweet, thx for the reply! Starting my install in the AM :thumbsup:
So what is the differance between the type 1 versions 1&2 that has no adjustments?
I know there's more set-ups out there! Re-adjusting mine hopefully today.
