How safe are wheel spacers?
Old 07-01-2012 | 12:06 AM
con5tant's Avatar
I just bought a set of 20 and 25 mm Ichiba V2 wheel spacers.
I was wondering how safe they were because i've seen some people with broken studs.
Old 07-01-2012 | 02:39 PM
05_NBP_TL's Avatar
HE>i
safe!
took a round trip of 1500 miles with my 15/20mm spacers. never had a problem with them for over 3 years. i have the Ichiba V2's also
Old 07-01-2012 | 08:14 PM
rptls08's Avatar
WDP Type-S sitting on air
i know a lot of guys with ichiba v2's with no issues at all. im getting ready to pick up 30mm spacers myself
Old 07-01-2012 | 09:58 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
You asking if they are safe,after you had already bought them
Some people have had issues,I would never use spacers but that's just me.
I guess if you are a spirited driver,there is a greater chance of something happening.
Old 07-01-2012 | 10:06 PM
con5tant's Avatar
Thanks for the replies guys
As far as buying them beforehand, there is something called a return policy...
Old 07-01-2012 | 10:45 PM
rockstar143's Avatar
there are very few incidents with wheel spacers and when they are, normally it's due to something silly like not installing properly or trying to run a version 2 10MM spacer...
J.
Old 07-01-2012 | 10:52 PM
con5tant's Avatar
When i googled "Ichiba V2 spacers" the first two results were: "Ichiba v2 Wheel Spacers NOT SAFE!!!" and "Almost DIED tonight thanks Ichiba V2 Spacers"
Old 07-01-2012 | 11:01 PM
I'm on v1's 10MM front/back OR v2's 20MM on the back (I rotate my mildly staggered setup). Fiancee's on 25MM rears and 20 fronts and have done a bunch of road trips on them.
Given the first thing people research without owning them, is whether or not they fail. It doesn't surprise me that that's the most popular search.
If you're worried, don't get em! EASY!
Old 07-01-2012 | 11:27 PM
Steven Bell's Avatar
You'll be OK with the spacers. I've got Akata's and love them!
Old 07-01-2012 | 11:33 PM
rptls08's Avatar
like any modification you do to your car something can always go wrong. im sure there are horror stories with any brand spacers including ichiba. however ichiba is a very reputable company that in my opinion sells a good product which i would trust over just about any other brand of spacers. the main thing to remember is to torque them properly during your installation
Old 07-02-2012 | 11:43 AM
^^^yep...and ESPECIALLY with the soft metal nuts they supply you. Torque to 80 ft/lb and no more. Check torque after a few days.
I go around 80 ft/lb on all nuts twice, so 10 times...when I've checked torque after a few days it usually won't go any tighter. Perfect.
Old 07-02-2012 | 11:58 AM
SharksBreath's Avatar
BANNED
i've ran different brands (ichiba, akata, h&r) and they're all basically the same.
one thing i will recommend you do is change out your OEM wheel locks (if you have OEM wheels). the litte indentation on the "lock" lug is prone to snapping in half with the extra weight of the wheel being supported by the lugs.
get a different wheel lock for each wheel. get one that has more of a grip/relationship with the wheel lock key.
con5tant (07-03-2012)
Old 07-03-2012 | 12:22 PM
MMMalex's Avatar
7th Gear
Getting hubcentric spacers will decrease the likelihood of anything happening. Not sure if v2's even come non hubcentric
Old 07-03-2012 | 02:49 PM
con5tant's Avatar
I've never heard of Akata spacers.
Old 07-03-2012 | 02:51 PM
BANNED
^eBay. about 1/2 the price of ichiba.
Old 07-03-2012 | 02:54 PM
con5tant's Avatar
What do you suggest for lug nuts? (Might as well buy a whole new set instead of just replacing each lock imo, unless there's a lock that will look similar to OEM lugs)
Old 07-03-2012 | 02:58 PM
BANNED
ball seat lugs are fine. gorilla is a popular brand.
Deadlocked3545 (06-25-2020)
Old 07-03-2012 | 03:05 PM
con5tant's Avatar
Actually, how about these in chrome?
Old 07-03-2012 | 03:06 PM
BANNED
as long as they're the right size (12x1.50) and ball-seat type made for OEM wheels...you're good to go!
Old 07-03-2012 | 03:13 PM
con5tant's Avatar
Oh...they're not ball seat. I'll look into gorilla's.
Thanks!
Old 07-03-2012 | 03:21 PM
The biggest problem with the oem locks is they're shallow...so since a lot of V2 spacers have studs that are slightly longer than oem, they hit the end and knock the lock portion off...
Old 07-03-2012 | 03:24 PM
BANNED
^right. that's what i was trying to say a few posts up.
need locks/lugs that have a grip to them...not a little star punch out.
Old 07-03-2012 | 03:38 PM
con5tant's Avatar
oh man...what are the differences between these two? they seem identical to me (except the huge price difference)
Amazon Amazon
Amazon Amazon
Old 07-03-2012 | 03:42 PM
BANNED
idk...they look the same to me.
Old 07-03-2012 | 03:56 PM
con5tant's Avatar
Oh...after a bit of research it appears that the first link is 20 wheel locks and the second one is four.
Old 07-03-2012 | 04:00 PM
BANNED
Old 07-03-2012 | 09:07 PM
sockr1's Avatar
http://www.amazon.com/Gorilla-Automo.../dp/B001O0AHZS
http://www.amazon.com/Gorilla-Automo.../dp/B001O0CLPW
i ran akata spacers but always felt like they gave extra vibration/uneasiness even though i checked the torque many times. after 2 weeks my OEM wheel lock broke off and I got paranoid and sold my spacers.
i have the gorilla locks you posted above and those are even more shallow than the OEM locks so they won't work with the long studs on the spacers. if you look at my threads there is one about spacers and i give dimensions for locks and everything in case you want to double check.
for me it was a matter of being paranoid or not...even though the spacers do give a great stance!
Old 07-03-2012 | 10:15 PM
con5tant's Avatar
ahh crap, thanks for the info..
Old 07-05-2012 | 01:54 PM
I run spacers V1 and 2 at any given moment, my fiancee is running V2's all around on her Accord and we've done road trips etc...no complaints at all. I guess to each their own.
Old 07-08-2012 | 02:56 AM
xavier_247's Avatar
I'm not sure on a TL since I recent;y just purchased mine but I ran a custom 2.5" set made by micrometrics for a wide body 240sx I previously owned with no issues at all. I actually had them on for years and never ran into any problems but alot of people I know don't like the thought of spacers for many reasons. My preference now is to alway have the best fit without but I have not witnessed the horror stories I hear in forums about spacer usage.
james357
02-13-2016 03:37 PM
jblessing
Wash & Wax
09-17-2015 10:28 PM
yvr_tsx
09-15-2015 02:14 PM
jmoney2001
09-11-2015 01:07 PM
mtl_ilx
09-03-2015 10:48 AM
